โAug-11-2014 05:56 AM
โAug-15-2014 12:35 PM
โAug-15-2014 10:14 AM
โAug-15-2014 10:11 AM
โAug-15-2014 09:39 AM
Bud
USAF Retired
Pace Arrow
โAug-15-2014 09:11 AM
โAug-15-2014 07:30 AM
mhardin wrote:enblethen wrote:
120 volt water heater element, the AC plus the converter is too much load for a 30 amp rig.
I've been doing it for years with no problem.
โAug-15-2014 07:10 AM
โAug-15-2014 06:43 AM
Bud
USAF Retired
Pace Arrow
โAug-15-2014 06:28 AM
enblethen wrote:
You should not be operating the 120 volt water heater element and AC unit at the same time.
โAug-15-2014 05:58 AM
โAug-12-2014 07:05 AM
BillB800si wrote:
When we had our 2007 Jayco Eaqle 322FKS we had an electrical problem the 2nd year. I finally found it in the electrical panel. Seems that after a few thousands miles of travel some of the wires in the panel had loosened up and was arcing. This caused a build up of resistance on the connections. Plus I found some of the wire insulation has melted off the A.C. wiring. I then cleaned up the terminals- reconnected the clean wires and tightened everything down.
That was the fix....
Hope yours is that easy.
Happy trails,
โAug-12-2014 06:13 AM
โAug-12-2014 05:37 AM
โAug-12-2014 05:15 AM
โAug-11-2014 10:05 AM
