Aug-17-2017 12:07 PM
Aug-18-2017 09:17 AM
wnjj wrote:SidecarFlip wrote:
No reason to replace all 8 when a couple exhibit a poor spray pattern or the pintles are leaking. Seldom do you replace all 8. One thing about earlier Duramax's is they are touchy with fuel filtration.....and Allison's require regular maintenance.
A good reason to replace all 8 might be someone who isn't a DYI where the majority of the cost is labor. The relatively incremental cost for the parts isn't worth it. If some are worn, the rest likely aren't far behind.
Aug-18-2017 04:26 AM
wowens79 wrote:
Thanks for all the feed back. I'm going to hold off till my son gets this one. I bought it when my wife was pregnant with him so I would have a back seat. Luckily it's been paid for since 2005, but I've been making payments to myself.
I'll probably go back with a gasser, at my tow weight I can't justify the cost of a diesel.
Thanks again!!
Aug-17-2017 07:45 PM
Aug-17-2017 06:48 PM
Aug-17-2017 05:59 PM
Aug-17-2017 04:49 PM
Aug-17-2017 04:41 PM
Aug-17-2017 04:24 PM
Aug-17-2017 02:09 PM
Aug-17-2017 02:00 PM
Aug-17-2017 01:45 PM
Txsurfer wrote:
I believe that when you are buying a higher mileage Diesel -you need to be prepared to drop $5G at any time for a repair. If you are good with that I'd say go for it. I may be out of line here but a set of injectors are not cheap for instance..
Aug-17-2017 01:41 PM
Aug-17-2017 01:06 PM
Aug-17-2017 12:53 PM
