Zero-G water hoses
penguin149
Looking at water hoses for next season and making my Christmas list. Thinking about getting a Zero-G hose but not sure which one.
Gray / Black "garden" hose says it's drinking water safe and it's 5/8"; more volume but more bulk to store
Gray Zero-G
Blue RV/Marine hose is 1/2"; less volume and see complaints that it says do not keep under pressure? Aren't all RV hoses under pressure when in use?!
Blue Zero-G
Which one is best for travel trailer use?
2021 Nissan Titan Pro-4X 5.6L V8 4WD - 2019 Keystone Bullet 243BHS
34 REPLIES 34
penguin149
OP here!
Thanks for the responses and input. I'm going with the 5/8" gray/black hose for greater volume. Regulator should control pressure regardless on diameter.
Gray Zero-G
Blue Zero-G
I contacted the manufacturer of the Zero G to ask if I should use the RV hose for our trailer. Here is their response:
Thank you for your inquiry.
All of the Zero-G hoses that we make are drinking water safe, made from all virgin materials. The 1/2" diameter ones (as opposed to the 5/8" ones) are simply marketed differently. There is no difference in manufacturing, except for the inner diameter. It would be a personal choice whether you want the Zero-G RV/ Marine hose or the regular Zero-G hose.
Sarah Flory
Teknor Apex Customer Service
505 Central Avenue
Pawtucket, RI 02865
800-289-6786 Ext. 3158
To expand on that note, the is what they sent me - -
Hi Joe,
Thank you for your inquiry. If you have the hose hooked up to an RV and are using a pressure regulator with it, it will work there is notice on the label that the hose is not meant to be left under pressure while unattended but in this application there is an exception.
Stephanie Fontaine
Sfontaine@teknorapex.com
Senior Hose Customer Service Representative
1-800-289-6786 ext 3419 Direct Line : 1-401-642-3419
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
DanKirk
Gray Zero-G
Blue Zero-G
Sarah Flory
505 Central Avenue
Pawtucket, RI 02865
2017 Windjammer 3006WK
2011 Dodge Ram 2500 4X4 Crew Cab Cummins Turbo Diesel
Lynnmor
I have camped at many places with bad water. The most memorable was one in south central PA that was back a quarter mile extremely dusty drive. When I arrive, I too flush the hose before connecting, so this time I sprayed the dust off the rear of the trailer. I noticed that the water was brown so I flushed some more with no improvement. Went over to the maintenance guy and asked about it and was given permission to flush till the water came clean. It never did and I never hooked up.
I have other stories, but I am convinced that most hook up without a clue.
Jeez..
I need to know where some of you camp so I can stay away !
In my 40+ years of camping, I cannot remember 1 time that I had dirty, brown, rusty water supply...
When I get to the site, the first thing I do is turn the faucet on BEFORE hooking the hose.. IF there is any sediment sitting from not being used for a while, that will flush out..
NOW.. We DO NOT drink any camp water, no matter where we are.. We bring along bottled spring water.
Me-Her-the kids
CharlesinGA
afidel wrote:
......if I've got water at the site it's a heck of a lot more convenient to not have to even think about how much I'm using, plus there's no noise and vibration like with the pump.
I do not use the hose hooked to the RV and pressurized. Only once have I done that. You don't have to worry about waking up in the middle of the night and discovering the floor is awash in water. Guy at work had that happen. Had some relatives with him, one of them took a shower and left the shower head in the "drip" mode with the faucets on. During the night the gray tank overflowed and the shower pan filled up and the trailer filled up. Insurance totaled the trailer.
With the pump, you know if you have a leak, faucet on, etc, you hear the pump cycling. My complaint with the trailer I have now is the pump it TOO quiet, I can barely hear it. I only turn the pump on when I need water or am using it frequently (meals, etc), anytime away from the RV, or not using it for extended periods, at night, etc, pump is off.
Charles
'03 Ram 2500 CTD, 5.9HO six speed, PacBrake Exh Brake, std cab, long bed, Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
LVJJJ
Love my zero g, hated my white non zero g. Got one when they first came out. 12' 5/8". I never read directions or ask for them, I'm a male!!
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
rbpru
Speaking from experience, just on time hooked up to a campground supply that stinks, tastes funny and looks rusty; and you will appreciate that extra 15 to 20 gallons in the fresh water tank.
I prefer the taste and smell of my own well water. 🙂
chuckbear
I think some of you are confusing Zero G with other brands of hose. I shop both Lowes and Home Depot and the Zero G hoses sold at both have metal ends. I have never seen Zero G hoses with plastic ends anywhere. Ours is out in the sun all the time here in Florida and shows no signs of deterioration. We use it all the time hooked up to the pressure water at the campsites. The bursting strength on the zero G is 650 PSI. If a campground produces more than that water pressure, there is a serious problem. Ours gets run over by the cars often when stretched across the driveways at home. No issues there either. Chuck
GrandpaKip
I replaced the marine/RV hoses with Zero-G hoses because it was a pain to coil them, especially when cold and put them in their Rubbermaid container. In addition, seems like the white hoses always got a kink in the same place. I don’t miss the white ones at all.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Bumpyroad
how did I get by all these years with my white hoses and not have all of these dire consequences??????????
bumpy
hondapro
I have a zero g hose and a flexzilla I like them both and they both work much better than the cheap white hoses.
My zero g hose is the gray color, the only issue I have with it is at times when it is laying on the ground in the grass it can look very much like a snake.
Steve
2023 Ram 3500 6.7 Cummins Turbo Diesel
2022 Keystone Sprinter 32BH
B&W Companion
Blazing_Zippers
After rolling around in the grass trying to roll up a white water hose, we bought a blue 50 foot EZ hose. No issues, no leaks yet, coils easily, and stores with the filter in a plastic trash can. I put a pressure reducer and the filter on the spigot first, then the blue hose.
Our issue with the white hoses were that they were so stiff.
Each to their own preference.
dieseltruckdriv
Bumpyroad wrote:
afidel wrote:
I'm not afraid to, but if I've got water at the site it's a heck of a lot more convenient to not have to even think about how much I'm using, plus there's no noise and vibration like with the pump.
x2, who wants to hear that pump a shakin all the time?
bumpy
I got rid of the vibrations by using pipe insulation where the piping contacted walls, and almost all of the noise went away, so it was a win win.
We almost always boondock or dry camp, so it is natural to leave home with a full tank of fresh water. Two years ago, we were at a state campground and the water smelled horrible. Several of the folks we were there with ended up getting, well, they couldn't wander far from their toilets. We had our normal water, and my DW said we will NEVER leave home with an empty water tank, I of course said "yes dear".
Edit to add: We know we can go through two fresh tanks before we have to worry about our black and bathroom grey tanks, so we don't have to worry about those stupid gauges not working.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
