So what did you do to your Truck Camper today?
Mello_Mike
I saw these threads in some of the other Open Roads RV Forums, but didn't see one for TCs.
I'll start...
I installed Interior LED puck lights and a 12v power outlet.
2016 Northstar Laredo SC/240w Solar/2-6v Lifeline AGMs/Dometic CR110 DC Compressor Fridge
2013 Ram 3500 4x4/6.7L Cummins TD/3.42/Buckstop Bumper with Warn 16.5ti Winch/Big Wig Rear Sway Bar/Talons w/SS Fastguns
My Rig
1998 Jeep Wrangler
US Navy Ret.
3,114 REPLIES 3,114
dakonthemountai
narcodog wrote:
Continued to repair the rotten floor next to the door.
So you left us??!! I never even got to meet you before you left the mountain!! 😞 Oh well. Now you can have a much shorter drive to camp when I come down! 🙂
All the best to you!
Dak
2018 GMC Denali "Extreme" and 23' EVO 2050T Travel Trailer
Escapee member #224325-Since 1992
JumboJet
Unloaded the camper after a weekend trip and have two Fastguns that warranty will take care of. Adjusting nut has galled Completely STUCK on one, and the other required extreme force (24" pipe wrench) to adjust enough to hold the camper to the tiedown. On the one that was completely stuck, I cut the SS rod and added a Tractor Supply 1/2" turnbuckle to get me out of a "jam" - pun intended.
I have had SS bolts and nuts do this before. Might add some anti-sieze compound when assembling replacement parts.
narcodog
mountainkowboy
Loaded her up and moved her down to the new house.....how do I change my name to Desertkowboy?
Chuck & Ruth with 4-legged Molly
2007 Tiffin Allegro 30DA
2011 Ford Ranger
1987 HD FLHTP
JoeChiOhki
Camper_Jeff_&_Kelli wrote:
Got the camper loaded and heading to Florence, OR in the AM for the Rhodadenderon festival in florence. They put on a pretty decent parade and the car show at the Three Rivers Casino is good too. Looking forward to a little fun and sun.
J
Well, you'll get around 3 days of sun, Monday Oregon reverts to liquid sunshine for another week or two or three.
My Blog - The Journey of the Redneck Express
CB
Channel 17
Redneck Express
'1992 Dodge W-250 "Dually" Power Wagon - Club Cab Long Bed 4x4 V8 5.9L gashog w/4.10 Geared axles
'1974 KIT Kamper 1106 - 11' Slide-in
'2006 Heartland BigHorn 3400RL
billyray50
Installed mud dauber and insect screens on furnace, water, and fridge vents.
Camper_Jeff___K
Nomad III
Nomad III
Thanks for the suggestions. I am looking at saturating the area with epoxy but after I resolve the leak. Here is a picture of the area. The wet point is on the bottom edge just inside of the compartment door. It only gets wet in the center. It is always dry to either side of the spot. How's that for a brain teaser! There is a drip cap ofer the top of the door and the door never gets wet. The bolts holding the rear jacks in place have all been embedded in caulk. Everything is caulked. Here's a picture of the area. The picture is older and everything has been caulked since this was taken.
I put a second bead of caulk over the left rear tail light so we'll see if that does it.
J
dakonthemountai
I replaced the 17 year old propane regulator with a new auto-switchover one, put permanent POL adapters on both horizontal tanks and all new hoses 🙂 I have to get the tanks re-certified before I can get them filled again (only one is empty though) Then it's done! 🙂 on to the next project!
Dak
QualitySnowman
I loaded my TC from my seasonal site onto Dr. Diesel to head up to South Bass Island State Park / Put In Bay for some fishing off a buddy's boat and bar hopping at night. Little nervous about the whole 5 mile ferry ride on Lake Erie to get there. Adventure! 🙂
~82 Brian "QualitySnowman" Snowden :C
~06 Ram 2500HD Quad 4x4 Laramie 8' Cummins 5.9 - 5" w/o Muff or Cat, Prog, 35's, Intake.
~13 Streamlite 27RKS 32' Champagne Ed.
~07 Honda Rancher 420 EFI 4x4 - 2" Lift, ITP 212 Alloys & 26" MudLite XTR, 2.5k Winch, Camo
big_whitey
hey Buzz can i be your new BFF?
Buzzcut1
Nomad II
Nomad II
I lent my truck and horse trailer sans TC to a friend for the weekend so after washing the dust off the truck I reloaded the TC and cooked up a nice breakfast before going to work on the Ambulance for the day.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
JoeChiOhki
Oh, I forgot to add, drove my truck yesterday in to work to haul back a load of lumber for a project out at the RV Park. 🙂
CB
Channel 17
Redneck Express
seraphim
Jeff it can get in anywhere, then run betwwen the inner and outer walls and collect at the low point, where it does the damage. Check everything that has a seal: window, vents, AC. The leak doesn't need to be right around the damage.
2012 GMC 3500HD Crew Cab LB 4x4 DRW with Duramax 6.6 diesel
2013 Palomino Maverick 2902.
JoeChiOhki
Hit the wood with some Minwax wood hardener as well, it embeds epoxy resin into the wood fibers and makes them water proof.
If you know someone with an old squirrel cage blower from a furnace you can rig up a pressurization system to do a leak trace on your camper using soapy water.
CB
Channel 17
Redneck Express
Camper_Jeff___K
Nomad III
Nomad III
Still trying to figure where a persistant leak is penetrating from on the left rear corner of the TC. Removed the Left rear tail light assembly and removed the putty it was set in and am setting it in QUAD caulk. Also did more caulking in the near areas that could possibly be an entry point. I do have a little wood rot begining so I saturated the area with Wolman end cut preservative for treated lumber decking hoping that will if nothing else, slow down any advance of rot. The affected area is small and for the life of me, cannot figure where the water is getting in there from.
Jeff
