Dec-28-2020 01:23 PM
Jan-02-2021 06:16 PM
Dec-30-2020 03:34 PM
Dec-30-2020 02:52 PM
Dec-30-2020 11:42 AM
learntorv wrote:RobWNY wrote:
With the cost of the vinyl fence post tubes, the caps, hinges and brackets and then having to put it all together, wouldn't it be better to just buy one of these? Valterra Adjustable Hose Carrier
My toy hauler came with the Valterra mounted from the factory. I then made 2 more vinyl fence posts for the rig.
Other than a stupid mounting location, it's harder to put the hose into than the vinyl fence post. The fence post also holds more.
Dec-30-2020 09:10 AM
Dec-29-2020 06:34 PM
haddy1 wrote:Sjm9911 wrote:
No, the valterra is a lot more $$$. Like double. I just bolted mine, and used a wing nut through the caps. But mine has a ladder in it and not a sewer hose. Caps were at the same place i got the fence post, lowes.
OK, Here's one for 1/2 the price.
https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwi1gMay4PTtAhVMvsAKHTLhASgYABAHGgJpbQ&ohost=www.google.com&cid=CAESQOD2pUjsNJg-WPIZRDudsQH8V1ZMuP5_-aDyoPqE9nkhKR4gMRj0QcmOnqWLknu9nYAZyFGz-FCgu5wjqrl4CpM&sig=AOD64_2MtL9vyGxBPZBFtLanANXlD1pf2w&ctype=5&q=&ved=2ahUKEwijvb2y4PTtAhUFLs0KHdl2BtMQ9aACegQIBhBC&adurl=
Dec-29-2020 06:24 PM
Dec-29-2020 07:35 AM
Dec-29-2020 06:07 AM
Dec-28-2020 05:24 PM
marty1300 wrote:
My Lowe’s had the post but not the cap, they ordered it for me.
Marty
Dec-28-2020 05:23 PM
Tom_M wrote:
I used a router to cut slots in the bottom to act like a spring. Short screws act as pins that go through holes in the cap to hold in place. A length of vinyl gutter acts as slide out tray.
Dec-28-2020 05:18 PM
rhagfo wrote:Jay Pat wrote:rhagfo wrote:Jay Pat wrote:
Using 5" square plastic post.
Can't find 5.5" plastic caps....
Interested in other ideas for different cap material.
Thanks!
Pat
Is this what you are looking for?? We got ours and post at lowes.
This looks exactly like what I had on the previous rv.
The cap was large enough to put the hinge on inside the cap and still had enough room for the cap to close over the post.
Are your caps 5" or 5.5"?
All I can find are labeled 5" caps.
They are 5" caps, they have a slight modification to the bottom to close.
As to the Valterra A04-5094BK EZ Hose Adjustable Hose Carrier - 50" to 94" it is only 4-1/2" in diameter so most likely going to get the elbow fitting in the tube. ALL of my stinky Slinky parts go in the fence post.
Dec-28-2020 04:49 PM
Dec-28-2020 04:30 PM
