A shade blocks light from inside, it won't keep the sun and heat off the glass, and unless see thru, you can't look out
I like window awnings, they shade the window, keep the sun off, you can look out, you can open the window of you wish, even in light rain
I if it's too low for some people you see out,
Use a small short bungee cord, or cheap dollar store dog collar
To extend the pull down strap so the awning roller is a little higher, not extended all the way
I can explain it to you.
1997 F53 Bounder 36s
