โMay-01-2014 06:48 AM
โMay-14-2014 02:00 PM
โMay-06-2014 05:19 PM
smkettner wrote:Larryect wrote:
When I did mine I had some trouble finding a 12 volt relay. I think I found it at Allied electronics on-line. I had to add a resistor for the appropriate time-delay.
I had read about the mod on-line. It was a very good write up with instructions and links to a source for a cheaper relay. But at that time the cheaper relay was no-longer available.
For the life of me, I can't find that detailed write up again.
This should be it
If someone wants my agastat, send PM
โMay-06-2014 02:29 PM
โMay-06-2014 02:22 PM
shooted wrote:bob213 wrote:
Look at this thread. OP changed wiring method so correct way is from post #13 on.
Fan delay
Great minds think alike! I was thinking of this exact thread. Strange, I contributed to that thread and all of my posts are missing. This is the reason you will notice some gaps in the conversation.
โMay-06-2014 02:11 PM
โMay-06-2014 02:00 PM
โMay-06-2014 01:13 PM
C Schomer wrote:
The best thing for starting an AC compressor is to have the pressures equalized and that gets done faster by running the fan. If you want to get creative with delays, stop the fan for a couple of seconds when the compressor wire get a call from the tstat. That will help the pressures equalize and kill the fan power for a moment at compressor start up. Craig
โMay-06-2014 12:29 PM
Fan delay
โMay-06-2014 11:55 AM
gbopp wrote:Reading the specifications, says 18 to 240 volts AC, an older catalog for the same switch states 18-240 volts AC/DC. Inquiry to ICM produced this response:
Clicky
โMay-02-2014 12:00 PM
โMay-01-2014 11:46 AM
โMay-01-2014 11:43 AM
โMay-01-2014 11:33 AM
Larryect wrote:The relay should go in the circuit to turn the blower on, not actually power it.
The problem I see with what you are suggesting is that relay is rated for 1.5 amps. I suspect the fan has a higher amperage. The relay would not last long before burning up if the fan draws more than 1.5 amps.
โMay-01-2014 11:00 AM
