fan delay on make timer to help start up for ac generator
rockwind1
along with the spp6, i was going to install one of these delay on make devices to save a couple start up amps.
http://www.amazon.com/Icm-ICM102-Time-Delay-Relay/dp/B000LDGFL4/ref=sr_1_1?s=industrial&ie=UTF8&qid=1398903668&sr=1-1&keywords=delay+on+make+timer
has anyone put one in?
i would be tempted to put it inline with the 110 v fan wire vs. the thermostat wire,
also, my front ac doens't have a wall thermostat, just a "cold-colder" rotating switch on the unit.
any advice or tips from someone who has traveled this path?
thanks for looking at my post, kevin
17 REPLIES 17
WDP
Received the ICM Controls ICM102B timer and it works. Took about 5 minutes to install, moved the thermostat fan low connector to the relay, made up a short jumper back the the control panel. Secured with a screw to the interior of the air filter plenum. Set at minimum, I get 2.5 seconds of delay, the adjustment is not linear, a small increase jumps the delay to 20 seconds. Maybe a bad unit. I turned off the converter and ran the batteries down to 11.35 volts and it still timed and latched reliably.
WDP
Larryect
smkettner wrote:
Larryect wrote:
When I did mine I had some trouble finding a 12 volt relay. I think I found it at Allied electronics on-line. I had to add a resistor for the appropriate time-delay.
I had read about the mod on-line. It was a very good write up with instructions and links to a source for a cheaper relay. But at that time the cheaper relay was no-longer available.
For the life of me, I can't find that detailed write up again.
This should be it
If someone wants my agastat, send PM
Could be. Your post on the second page nails the process. Seems to me the one I saw before had pictures - but maybe not.
This worked great on my old Dometic with analog t_stat. Don't know if it would help the OP with controls in the housing, or with the new didgital stat's.
time2roll
This should be it
WDP
shooted wrote:
bob213 wrote:
Look at this thread. OP changed wiring method so correct way is from post #13 on.
Fan delay
Great minds think alike! I was thinking of this exact thread. Strange, I contributed to that thread and all of my posts are missing. This is the reason you will notice some gaps in the conversation.
Pic shows 7.5 volts on the thermostat, not likely with everything running off of 12. If it works for this poster, sounds like a mod to try.
WDP
Larryect
time2roll
I think I would mate that timer with a relay that could easily handle the fan running amps.
1.5 amp rating seems a bit light.
And yes I had installed similar in the wall thermostat control circuit. Worked great. agastat was the delay unit and it was 12v based. 12v is hard to find as most units (non-RV) are controlled with 24vac.
shooted
C Schomer wrote:
The best thing for starting an AC compressor is to have the pressures equalized and that gets done faster by running the fan. If you want to get creative with delays, stop the fan for a couple of seconds when the compressor wire get a call from the tstat. That will help the pressures equalize and kill the fan power for a moment at compressor start up. Craig
To increase component life expectancy and to lower amps drawn by the compressor on startup, a low pressure differential is important. In this application equalization takes place during the compressor off time when the high pressure side bleeds thru the cap tube to the low pressure side. Fan operation, or the lack there of, will have little to no effect on equalization. Ensuring the system(compressor) has enough time(off) is the important factor concerning equalization.
shooted
Fan delay
WDP
gbopp wrote:
Clicky
Reading the specifications, says 18 to 240 volts AC, an older catalog for the same switch states 18-240 volts AC/DC. Inquiry to ICM produced this response:
RE: Product Inquiry : ICM102 - Delay-on-Make Timer with .03-10 minute adjustable delay, universal 18-240 VAC
Pete:
One thing to note, the timer will not work on only 12VDC. It took 18VDC to latch. This makes sense because it is rated 18-240VAC and the old books state 18-240 VAC/DC.
Regards,
John Fannetti
ICM Controls
7313 William Barry Blvd
North Syracuse, NY 13212
315-362-9363
Now, my question, does anyone have one in service that works on 12 volts DC? (control voltage for air conditioner)
Thanks in advance.
WDP
C_Schomer
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
Larryect
That would be great. But, I don't think it is what the OP is suggesting.
I don't have a wiring diagram for the unit. He either needs to match the voltage to the thermostat voltage and interupt that, or match the votage and amperage of the wire he is suggesting to interrupt.
When I installed something similar, I did it on the (remote) thermostat wire. I really don't know what is available considering his themostat is built into the distribution box on the unit.
TurnThePage
I added a delay timer, that was suggested by another forum member, which required a resistor be added to specify the delay time. It appears to be no longer available unfortunately. It was added to the fan control fed from the thermostat. The only time it was used was during initial power up of the AC. On a side note, it would be easy enough to simply add a fan on/off switch that would allow you to turn it on yourself after the compressor is on line.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
TurnThePage
Larryect wrote:
The problem I see with what you are suggesting is that relay is rated for 1.5 amps. I suspect the fan has a higher amperage. The relay would not last long before burning up if the fan draws more than 1.5 amps.
The relay should go in the circuit to turn the blower on, not actually power it.
2015 Ram 1500
Larryect
