โMay-31-2018 06:41 PM
โJun-04-2018 06:10 AM
โJun-04-2018 02:41 AM
โJun-03-2018 12:48 PM
โJun-03-2018 10:09 AM
โJun-03-2018 10:05 AM
GordonThree wrote:
Well poop. The Vortex is here already, but I don't see how it is a retrofit as advertised: install without breaking the roof seal.
The last vortex came in a frame that replaced the inside portion of the roof vent, and attached to the cross member that contains the skylight mechanism.
This is all one unit, complete with roof flange and everything.
Not terrible I guess, just means I'll have to figure out how I'm going to replace the existing vent in the middle of my non walkable roof... I could barely reach the sides to install the vent cover.
โJun-03-2018 09:35 AM
Blacklane wrote:
I was going to install a similar PWM speed controller on a Heng's fan, but discovered (a) it made an loud high-pitched noise whenever the fan was set to any speed other than full, and (b) it drew several milliamps of parasitic current while turned off.
Maybe this controller is better, but those are a couple of things to maybe test before cutting and drilling.
I did install the speed controller on my stove vent and it works great. I installed it down-stream of the existing switch to avoid parasitic current draw.
โJun-03-2018 08:52 AM
โJun-02-2018 11:35 PM
โJun-02-2018 05:55 PM
โJun-01-2018 06:23 AM
GordonThree wrote:IAMICHABOD wrote:
Do you have a link for that?
Here is the fan:
Vortex III
And the controller:
Cytron
โJun-01-2018 06:21 AM
Here is the fan:
Vortex III
And the controller:
Cytron
โJun-01-2018 05:03 AM
โJun-01-2018 04:58 AM
โMay-31-2018 10:56 PM
