Home made slide out cargo tray
Bob_Vaughn
I want to build a cargo tray to go in the basement of my 5th wheel. I cannot afford the 500-600 dollars for a professionally built and installed one. There has to be an economical way to build one. My main objective is to get my tool box into an accessible position. I built slide out trays in the pantry's in my rv and they work good. Any logical and practical and cheap suggestions would be appreciated
26 REPLIES 26
DrewE
I would think the roller spacing needed would depend largely on the amount of stuff you need to support. One foot would be more than sufficient, I believe; most garage doors have wider panels than that, maybe 18 inches or two feet, and said panels are not particularly lightweight. Some are downright heavy, even.
Bob_Vaughn
I have found some photos of a tray made from a garage door track and rollers but I cannot determine how close the rollers have to be together for a tray about 4-5 feet long. I just wonder if 1 foot apart is sufficient?
gaymeadowsman
I made one for our Surveyor about 3 weeks before a tree limb went though the roof and totaled it out. I removed it and hope make adjustments in it so it will fit our new trailer. I will try to post pictures of what I did this evening whe I get home from work.
John ๐Ÿ˜›
Ted :R
in search of the next one
2010 Chevy Silverado Ext Cab LT
2015 Chevrolet Impala LT
Ropdoc
Escargot wrote:
The following would be overkill for your application and I'm posting it only for the mechanics of this gal's solution to slide out storage:
DIY clicky
I want to build something like in my 5th wheel front pass thru storage. I want to make it so it pulls out either side. I will mount my mini lathe on one side and router table on the other. Table saw and other tools set in between.
Escargot
DIY clicky
2006 Pleasure Way Plateau TS, MB Sprinter
navegator
Check the tool boxes they also have some pretty strong slides, we had a nut that used to take a siesta on the bottom drawer of his Snap-on tool box, 200+
pounds of character.
navegator
MrWizard
Moderator
Moderator
something like this..these are 500# pantry slides
[IMG]http://i298.photobucket.com/albums/mm251/Mr__Wizard/Generators/2011-01-18_15-22-51_336.jpg" wid...
I can explain it to you.
1997 F53 Bounder 36s
agesilaus
Itchey Feet wrote:
For heavy duty slides, find an old popup camp trailer that someone is trashing out, get the slides from under the beds and build your own custom slide trays.
Hey I have one of those, thanks for the idea.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
Itchey_Feet
My feet are fine as long as they are traveling.
riggsp
Long heavy duty drawer slides...up to 60", and capacity up to 500 lb can be found with a Google search...make a shallow tray or use 3/4" plywood for a flat platform and attach to the floor of the basement.
MrWizard
Moderator
Moderator
Can't find the link..But this topic has come up before
Several members have done this..including me
Search my posts and you will find some pictures and info
Good 24" heavy duty PANTRY slides will set you back about $130 for a pair
The rest is just marine grade 3/4" plywood and Aluminum Angle for mounting the wood to the slides
I'll post the picture links after I get to my pc..I'm on my tablet
rv2go
I don't have pictures, but met a guy that made slide outs for his MH out of garage door tracks and rollers. Looked real good and worked.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
