How to make a cordless drill mount for the RV
RVcircus
Well, after a few years of digging through the toolbox for my drill every time we setup and breakdown camp I finally got sick of it. I needed to find a way to keep a cordless drill handy for putting the stabilizers up and down. I wanted the drill in the same place each time I needed it and I don't think that's asking too much.
I've been planning to add some basic drill mounts to the workbench at home and was leaning towards a basic PVC mount that a lot of YouTube woodworkers have done. So for this project I started with that idea and added a few features to make it roadworthy.
Here's a list of supplies and tools I used for this project:
* Short (7-8") section of 3" PVC pipe
* Old piece of thin shock cord/bungee cord
* 1/2" thick piece of foam (floor mat)
* Contact cement (I use Barge cement)
* Paint
* 3/4" wood screws
* Drill
* Dremel
* Jig saw
* An old drill to keep in the RV
Once you have the materials together the build is pretty quick and easy. It took me less than an hour to get it together and painted and I was winging this build (like most of our other stuff). Checkout the below video to see how I did it and I've included steps below just in case you need them.
https://youtu.be/eE7IMU_pHNI
Step 1: Cut a section of 3" PVC to length.
Step 2: Cut the slot to the handle to fit it. Make sure the trigger rests below the bottom of the PVC. I used a jig saw to rough out the shape and a Dremel to smooth it out and tweak the shape of the opening.
Step 3: Drill 1/4" holes on the side to attach a piece of shock cord. This will hold the drill in the mount when driving down the road.
Step 4: Heat and flatten the top of the PVC. I wanted a flat area to mount this to avoid having the weight of the drill shake the screws loose.
Step 5: I used contact cement to attach a 1/2" thick piece of foam to the inside top of the mount. This was to stop the drill from jumping up and resting on the trigger while the shock cord pulled the drill forward into it.
Step 6: Paint it a pretty color. There's nothing better that a flashy tool holder, so I went with black. I used black Plasti Dip for that extra bit of bling, but feel free to use any color you want as long as it's black. I think Henry Ford was onto something there.
This was a simple and cheap project that served a well needed purpose. Have you done something similar or have a better idea? Post it below.
2000 KZ Sportsman 2505 (overhauled & upgraded 2014)
2016 Chevy Express 3500 15 passanger van
6 humans, 2 cats, and a dog
Visit our blog at www.ROWLESmade.com
Our trailer re-build thread
19 REPLIES 19
RVcircus
98coachman wrote:
westend wrote:
Well, now you're getting **** fancy....:B:B:B
It's a great idea. Now you need a bit caddy underneath to hold a few of your most used bits and the square socket adaptor for your sockets.
I've gotta confess: I may as well just throw out all my screw drivers. I can't turn a fastener without an impact driver or cordless drill anymore.
X2 Nice Job!!:C
Thank you!
RVcircus
Ha!!! I'm all about fancy these days;) I threw a socket adapter and socket in the drill and have a #2 square drive in the drill bit holder. I might throw a set of bits on the wall just in case.
I think I'm in the same boat with screwdrivers. I have a million of them and I tend to use them to stab and pry things more than screw things.
98coachman
X2 Nice Job!!:C
westend
'03 F-250 4x4 CC
RVcircus
Bucky Badger wrote:
It was really a great Idea. I love your videos, you make them great by FF in parts of them. Keep up the good work
Thank you!
Bucky_Badger
RVcircus wrote:
jake2250 wrote:
Dang Nab It,, mine came with a nice plastic case that holds an extra battery,bits and what not,, I'd have to chuck the case out and build extra battery storage and dangle a bag for the bits,, great idea for home work bench though!!
Ha, my case went in the trash long ago. If I had all the cases for my tools I'd need a 2nd garage to store them:B
My goal was to not open any extra boxes to get my drill to lower my stabilizers. The drill already has the socket on the end, so it's grab and go. If I need to use it for something else I'll open my toolbox.
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
RVcircus
Bucky_Badger
Now all you have to do is look for the charger :B
and
2009 Nomad 3980
jake2250
2012Coleman
I use the manual wrench that came with the TT - insert the end into my cordless drill and away she goes...
2018 RAM 3500 Big Horn CTD
RVcircus
mgirardo wrote:
A cordless drill with several bits, including a square bit is about all the tools I travel with in the RV. Almost everything in the RV can be serviced with just a few bits.
Nice work as always.
-Michael
With a somewhat old trailer and older truck I always seem to need the tool I don't have. It doesn't stop me from trying to bring them all though:B
RVcircus
RedRocket204 wrote:
RVcircus wrote:
Pops wrote:
Pictures would be nice.
Ooh, got the video.... thanks
When I shoot video I always forget photos. Apparently my brain can't handle both;)
All video is is a bunch of pictures. Just find an app that can extract pictures from your video and you'll have both.
Good idea, I've been taking screen shots on my video in a pinch. Thanks for the tip!
mgirardo
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
RedRocket204
I love me some land yachting
