โNov-02-2014 02:58 PM
โNov-27-2014 03:35 PM
SDurbak wrote:
I tried this and it didn't work - what am I doing wrong? I bought a 1600 watt Whistler inverter, connected it to my battery, turned off the breaker to my converter, plugged shoreline power cord (30A) into an adapter, then plugged it into the outlet in the inverter, turned the inverter on, and within 2 seconds the inverter was alarming and shut itself off. Nothing in the camper is turned on, and I even tried it with all the breakers off. Same thing - alarm, then off. I plugged a crockpot into the inverter, and it worked fine, so I know the inverter is functioning. Any ideas?
โNov-27-2014 01:31 PM
โNov-27-2014 01:19 PM
โNov-13-2014 04:21 PM
โNov-07-2014 11:41 AM
I plug my shore power cable directly into the AC receptacle on my inverter. I shut off the breaker to my charge converter, as Mr. Wizard said. All sockets are live with AC power provided by the inverter.
โNov-03-2014 02:47 PM
โNov-03-2014 01:43 PM
โNov-03-2014 08:23 AM
pumpshep wrote:
is there any way to plug a cord from the inverter into the wall and have it power all the sockets?
โNov-03-2014 06:08 AM
Moderator edit to re-size picture to forum limit of 640px maximum width.
โNov-03-2014 04:36 AM
pianotuna wrote:
Hi,
Doing what you suggest is illegal and dangerous.
Far better to run a cord to the shore power cord box and plug the shore power cord in. Be sure to turn off the converter, and set the fridge to propane.pumpshep wrote:
So i have a inverter installed, and i have to run a extension cord to the tv to the inverter, is there any way to plug a cord from the inverter into the wall and have it power all the sockets?
โNov-02-2014 04:09 PM
โNov-02-2014 04:05 PM
โNov-02-2014 03:21 PM
