Shadow Catcher wrote:
Color temperature is expressed in degrees Kelvin and a 3200K is about what you get with a conventional tungsten bulb. Bulbs in the 5600K range are actually closer to day light and bluer, but the blue disturbs the sleep cycle.
standard incandescent softwhite bulbs are typically 2700K, rather yellow looking.
Halogens get a bit less yellow and range from 3000K-3500K.
For myself I find 2700K rather dim looking and 5000K "daylight" is too over the top harsh for general lighting and I also find it rather dim looking.. 6500K is way over the top too blueish making everyone looking dead (zombies perhaps)..
For me 3000K-4100K is my just right point for brightness and decent color rendition..
It is really hard to find LEDs which TRUELY are the color temperature that they state so you will end up having to experiment with a bunch of different LEDS to find the ones that suit your taste..
I have had problems finding LEDS in 3000K-4100K range which I like, pretty much most of them is 2700K OR 6500K..
I also had a problem finding LEDs bright and small enough to fit into my Puck style lights which had G4 20W halogens..
Found
THESE LEDS which are Warm White or 3000K and they actually have the light output which matches the 20W halogens!
The color is really subjective (not to mention ACTUAL LIGHT OUTPUT varies, manufacturers tend to overstate the brightness) so if possible buy only one or two to try before committing to a large purchase..
