Morryde Suspension and Wet Bolt Upgrade
1L243
I have been wanting to upgrade the suspension on my 2017 Coleman 300tq Toy Hauler with Morryde CRE 3000 and the Wet Bolt kit. I ran into a couple of minor issues durring the installation that I thought I would mention them here.
My Rig only has about 7000 miles on it (off the top of my head guess). The stock components were in pretty good shape. the plastic leaf spring bushing were still in good shape.
The Morryde system replaces the plastic bushings with bronze bushings. The wet bolts will allow you to grease the bushings and moving parts. The shackles are at least twice the thickness of the OEM shackles.
The installation instructions call for raising the trailer so both axles are off the ground on both sides. For me this was a problem because I had just enough jack stands, blocks and jacks for doing one side at a time.
The old
The problem I ran into was getting the leaf springs to line up with the leaf spring bracket and the Morryde equalizer. I am pretty sure this is because I am doing one side of the trailer at a time.
I used a small hydraulic bottle jack to push down on the axle to line up the bolts and I used a ratchet strap to line up the leaf spring with the frame hanger. Besides that everything went pretty smoothly. Took me about 5 hours but I was taking my time.
The New
You have the choice during the installation to face the grease fitting to the inside or outside. My axles are 4400 lb 33 inch on center and I placed them facing out. I can get to them easily without removing he tires. Your application could be different and putting the grease fitting facing in for easier access.
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
22 REPLIES 22
ScottG
Make sure you run grease through those wet bolts right away.
Half of mine weren't even drilled all the way. Just far enough to have zerks pressed in them.
Lantley
I had the same thought. They are both nice upgrades, but the suspension mod is a bit more affordable.
19'Duramax w/hips, 2022 Alliance Paradigm 390MP >BD3,r,22" Blackstone
r,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
BakFlip,RVLock,Prog.50A surge ,Hughes autoformer
Porta Bote 8.0 Nissan, Sailun S637
KLYoung
Little bit of a price difference though.
I also agree !
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Cummins12V98
I concur!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
cummins2014
Lantley wrote:
I do believe disc brakes are a very worthwhile investment. I also believe drum brakes for large trailers should be obsolete. However the reality is drum brakes are not obsolete even though they are inferior vs. disc brakes.
I do not believe you need to upgrade to disc brakes just because you are upgrading your suspension.
Sure it would be nice to upgrade to disc, but the reality is they are 2 different systems.
It is still worthwhile to upgrade brakes or suspension without upgrading both.
If there was a choice to be made , it would be disc brakes long before the upgraded suspension .,
Lantley
Fisherguy
... and they work ...
06 Dodge Ram 3500 Cummins 6 spd std with a few goodies.
2007 Komfort 274TS, 480 watts solar, Trimetric 2025RV, PD9280, Honda EU2000i, Xantrex SW600
2019 Timber Ridge 24RLS, 600 watts solar, 3-100Ah Lithiums, 12volt Norcold Fridge
Cummins12V98
Because they are CHEAP.
Fisherguy
BackOfThePack wrote:
Drums are not only obsolete, they’re worthless when it really matters.
Be sure to add Anti-lock (Tuson).
Obsolete are they? How come trailers still come with drum brakes then?
Learjet
I've done the upgrade and to reach some of the grease zerts I use these two items...the first one works great and also locks on to the second angled piece for the hard to reach zerts:
https://www.amazon.com/gp/product/B00H7LPKKU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00DJHXYN6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
BackOfThePack
2004 555 CTD QC LB NV-5600
1990 35’ Silver Streak
Cummins12V98
Maybe so but IMHO it's a wast of money to do a half AZZ job. Until you have towed a RV with disk brakes, well ya just don't know. Anyone changing to disks will tell you "I wish I would have done it sooner".
Vintage465
I think you need to add "a lot" before coin and "s" to the word coin. Disk brakes are nice and better. Drum brakes have been working for years.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
