Philips 18W LED bulbs not for enclosed fixtures
Oldcow
Just bought and installed some of these bulbs. Of course my wife reads on the package after the install that they are not for enclosed fixtures. I save the packages and will return them. Thought I would post this in case there are others like me who did not know there was a difference.
Oldcow
2013 Outback 300RB TT
2010 Tundra
11 REPLIES 11
Oldcow
I left these bulbs in the fixture, they seem ok. For me it was just to see if there was that much difference with the brightness. Until I start doing more boondocking I don't see a lot of benefit for the cost. They are definitely running cooler.
Oldcow
2010 Tundra
4x4van
GordonThree wrote:
Glad to hear that cheap and simple Chinese made lamps work for you, and I'm sure to the naked eye they look brighter than the hotwire bulbs they replaced.
I build my own because I can.
Not trying to put you down for that, sorry if it came off that way. I could build my own as well, but with 28 fixtures, it's alot more than I want to take on when it's so easy and inexpensive to buy units that are now so clean and efficient.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
GordonThree
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
4x4van
Wow, alot of people seemingly going out of their way to spend alot of money and alot of complexity for something simple as LED lighting.
I just converted my entire RV to LEDs. The units I used this time (new to me MH; converted my previous RV a few years ago) were direct replacement BA15s bulb style with 120-3528 LEDs on them. They put out more light than the 1141 bulbs at nearly the same color and 1/5 the current. They cost only $3 each, and after an hour of run time, only reached 100F degrees.
Here they are.
GordonThree
Determined to get embedded photos from Google, trying again!
GordonThree
It used to be public. But I think Google expires the links after a while to stop us from embedding. I'll copy the image to Dropbox.
Fixed it maybe?
MrWizard
Moderator
Moderator
gordon, there is no picture only a 'no access' minus sign
you used a private secure link , to your private google acct
I can explain it to you.
1997 F53 Bounder 36s
GordonThree
Are we talking 12v or 120v lights?
An 18w 12v light would be even more impressive than a 18w 120v light.
Here's an 18 watt module for the porch light on my RV. It got too hot, over 100C at 18 watts, so I dialed it back to about 10w - it gets up to a toasty 60C or there abouts. The chips are rated to operate at up to 150C, but I think that'd be too much for the plastic housing the module is installed in.
It's still so much brighter than the 27w halogen bulb that was in there from the factory.
Oldcow
They are the regular type fixtures in a TT. Don't know how to post pictures sorry.
Oldcow
2010 Tundra
Ed_Gee
Oldcow
What kind of fixture are you installing that bulb in? I have some standard A19 LED bulbs installed in outside light fixtures that are air tight. They run a little warm in those enclosures, but no problems.... are your fixtures air tight, or is there a little ventilation?
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
GordonThree
Where? I'd like something more than the 7 - 10 watt junk the big box stores sell.
