Pin Box Bike Rack Mount
jurassicford
I've been lurking, on and off, here for many years. I've learned a lot and thought I'd provide some ideas inspiration to others. This was an easy project and only cost about $30 in materials to make. Any decent fabricator could do something similar for very little money.
Basically, it's 2" receiver stock that I picked up from Amazon.com, a couple pieces of 2" angle and some 3" flat stock (Tractor Supply).
Close up of the mount:
The bike rack is a five bike model from Allen Sports, also sourced from Amazon. I actually need to carry six bikes, but I think I'll use a ladder rack for the last kid-sized bike.
Showing the bike rack in the mount:
Another, showing clearance to the cap:
The welds aren't purty, but they're stuck and the entire thing has been primed, painted and clearcoated to avoid rust out front where it's most visible. I bolted it to the pin box with 5/8" grade 5 carbon steel bolts with thick washers on each side.
2004 Chevrolet Astro AWD "DisAstro"
2018 Keystone Springdale Mini 1800BH
12 REPLIES 12
CabinetmakerII
What a great idea! I have been looking for something commercially available. You should pattent this idea. Also I noticed the "D" ring on your break away. I use the same set up.
CURTCF! (C U Round The Camp Fire)
Cabinetmaker
2021 DRV 39 DBRS3
2017 F-450 4X4, Riece 24K Hitch
2011 F-450 4X4, Companion 18K Hitch, Air Bags (Retired)
2012 Cyclone 3800, 5th Airborne Kingpin (Retired)
2018 Polairs 1000 XP Side by Side
nremtp143
I did a very similar thing about 2 years ago. I have a long bed, but those that have short beds can just use a different style rack if the bikes accommodate it. Here are a couple of pics of mine.
2016 Montana 3790RD, Legacy Edition, G614s, TST TPMS
2008 Thor Vortex 26FS
2013 F350 DRW 6.7L 4x4, Edge CTS, B&W Companion, Viair 10007 Air System, Firestone Air Bags
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
Lantley
I agree the Arvika is pricey but I have no regrets. The rack works well and is adaptable to fit lots of scenarios. Arvika has figured out the pinbox bike rack.
4 bikes on the pinbox eliminates the challenge of bring bikes.
I had this same rack on my prior TT. This rack allowed me to transport bikes above propane tanks on my travel trailer.
jurassicford
Lantley wrote:
Arvika pin box mount. bike rack. No bouncing or shaking bikes are always in view bikes
The Arvika stuff is nice, but spendy. Although, it wouldn't be too hateful to copy their design and integrate a 2" receiver to use an off-the-shelf hitch rack. Looks like some 1" square tube and some sheet metal to hold it all together...
I really like your flush toolbox - it looks nice and keeps the bed rails clear. If I ever get tired of my $75 Craigslist special, I'm going that route.
jurassicford
BB_TX wrote:
I did something similar with a little different approach.
$20 receiver from Harbor Freight and some 2x2 angle I had laying around. Drilled holes to match the pin box bolts. Did not want to drill into my air ride pin box.
Shown mounted. Mount does not touch top of pin box. About 3/4" clearance at rear.
Shown with 2 bikes mounted. Have carried 3. Might could carry 4 without hitting the cab. It is a long bed. Bikes are bungeed to keep from moving and do not touch the trailer.
This is a pretty slick setup. I like how you mounted your bubble level below the bikes to keep it visible. I might tack a small plate onto mine for one of those big levels like yours.
Lantley
BB_TX
RCMAN46
I have a very similar pin box receiver mount on my 5th wheel. I have a short box Chevrolet 2500 crew cab and have been able to haul my bicycles with no problem hitting the truck cab.
jurassicford
SWD wrote:
OK...if you had a long box.
Fortunately, I do have the long bed. I think that this could work with a short box truck, but you'd be limited to two bikes or would have get the rack up higher.
jurassicford
agesilaus wrote:
Good idea
Ooops... I should have mentioned that I was inspired by another poster...
There's a couple of other folks here who have done something similar.
SWD
agesilaus
Good idea
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
