โJun-21-2014 03:47 PM
โJun-22-2014 03:13 PM
BTPO1 wrote:Not my experience. Once you aborb the vibration on the output side using flex hose, there's not much happening on the input side.
To reduce the noise you have to put the flexible hose on both sides of the pump,
โJun-22-2014 03:10 PM
pjhansman wrote:
I've mounted mine on rubber and wrapped all the lines in foam. Still not at all happy with the noise. I will try the flexible line on the pump discharge....but I think there's a pressure tank in my future as well.
โJun-22-2014 06:03 AM
โJun-21-2014 08:32 PM
BillyW wrote:
It's easy to make the current pump run quiet by isolating its vibrations from the rest of the RV. I mounted mine on sections of rubber hose and installed flexible hoses between it and the pex lines, and also added cushioning between the nearest water lines and the walls/floor.
โJun-21-2014 04:21 PM
โJun-21-2014 04:14 PM
