May-30-2017 07:58 PM
Jun-06-2017 04:27 PM
SoundGuy wrote:crcr wrote:
Thanks for all SoundGuy and Lynnmor, appreciate it. So I'm thinking two of these compression for Pex to Barb fitting for soft braided hose fittings might just fill the bill for my application. What do you think? Am I on the right track now?
That's one alternative but as I said earlier I don't see the need to cut the PEX at all if you can disconnect it from the pump, leave the PEX connector as is, and simply connect your soft braided hose to that connector, using adapters if need be.
Jun-06-2017 04:22 PM
Lynnmor wrote:
Looks good to me if that is indeed a 1/2" hose barb. Where did you come up with the part?
Jun-06-2017 01:22 PM
Jun-06-2017 12:58 PM
Jun-06-2017 12:44 PM
Jun-06-2017 10:47 AM
crcr wrote:
Below is a pic of my water pump. As you can see, no soft braided hoses on mine, unfortunately! So would those existing fittings to the Pex pipe likely be barbed? If so, then taking out a section of Pex and putting in a loop of soft braided hose would be pretty straightforward.
Jun-06-2017 09:54 AM
Jun-06-2017 09:38 AM
I've done several things to quiet down our water pump. I mounted it on a piece of 1/4" plywood with dash cover carpet material glued to both sides. Then I put water pipe foam insulation on the pipes around the pump. This has quieted it down quite a few notches, but to quiet it more, I am thinking to put in a soft vinyl tubing loop on the outlet side of the pump (almost all of the vibration in mine is on the outlet side, not the inlet side). My pipes are all hard Pex, and connections are secured with some kind of steel clamp that is obviously put on with some kind of special tool, thus the clamp, if removed, cannot be re-installed.
I am thinking of cutting the Pex tubing on the outlet side and installing a soft vinyl loop. My question is, should automotive-style screw clamps, used on heater hoses and so on, be adequate to hold the soft vinyl tubing over the Pex pipes without leaks? What is the typical pressure of these RV water lines when the lines are pressurized by the pump?
Anything is possible but a trailer manufacturer will usually use soft braided hose from the FW tank to the pump intake and if they give a **** at all then another piece from the pump output before it interfaces to PEX that distributes water throughout the trailer. In any case, the connections to the pump, if they're threaded, are standard 1/2" NPT (National Pipe Thread) so there shouldn't be any need to cut the PEX at all. Shurflo makes barb to 1/2" NPT adapters as well as 1/2" NPT to 3/4" GH (garden hose) adapters which would allow you to use braided fresh water hose. In my case I cut the 3/4" GH fittings off the hose I used because at the time I wasn't aware of the 1/2" to 3/4" adapters, otherwise I'd have used them.
Shurflo Fittings
Never use a band clamp on PEX, it's sure to leak. If you're really convinced you need to cut the PEX then use compression fittings that just slide on to the PEX and create a 1/2" NPT fitting on the end.
Jun-06-2017 09:25 AM
Jun-06-2017 07:54 AM
Jun-04-2017 07:56 AM
Jun-02-2017 02:54 PM
Lynnmor wrote:LarryJM wrote:
IMO those accumulator tanks use up a whole lot of unnecessary anti-freeze or extra isolation valves to by pass them like your WH during winterization.
I think there are better and less complicated ways to solve at least noise issues.
Larry
The tanks hold 24 oz. at full pressure, and only a fraction of that at zero pressure. You have zero pressure in a winterized trailer.
Jun-01-2017 04:16 PM
Jun-01-2017 11:24 AM
SoundGuy wrote:Bill.Satellite wrote:
If 2 feet works, why would I need to try 15'-25'? Not sure what's going on with your coach but in all the years of reading these kinds of post I have NEVER seen anyone post that they used or needed 15' of coiled hose to quiet their water pump. IMHO, if you do, something is terribly, terribly wrong.
In hopes of calming your response, I really don't care. Use all the hose you like but the majority of RVers will never have any need for anything like a 15' loop (wrapped in whatever).
But as you say - I really don't care whether you agree or not, I've got the proof that pump vibration largely radiates out through the output hose and the more soft potable water hose that is used before it eventually connects to the trailer's hard wall PEX system the greater will be the dampening effect. In my case, I do have the personal experience to prove this is the case. 😉
Jun-01-2017 03:25 AM
