50 amp cord
ipeltier
We have a 50 amp, 25 ft power cord (which weighs a ton) for our Jayco HT. At a Camping World in Spokane last week, we bought a 15 ft 50 amp cord for when we need a short connection. We crossed the border into Canada on the way home, went to use the 15 ft cord, and the connector to the RV is different. Is there an adapter that will make the RV connection compatible with the power cord?
11 REPLIES 11
ipeltier
ScottG--I used your link and found the item on Amazon Canada. Thanks!
Bumpyroad
golf_bears wrote:
Bumpyroad, he's talking about 50 amp cords and the need for a 50 amp connector. He's been given a few good suggestions already.
boatsUS also has the same item in 50 amp. it was the cheapest place I could find marinco stuff.
bumpy
golf_bears
Bumpyroad
the best price I found for the 30 amp Marinco was a short length at boats USA or somesuch. cut off the plug and put a standard 15/20 amp plug on to run an extension cord to.
bumpy
ScottG
I suspect this: linkaroonie is what you need.
I did the same thing; bought 15', 50A extension and used this adapter to attach it directly to my RV.
david_iona
You can buy an adapter at rv supply stores or on line about $20 or so.
Dave
rhagfo
You could also just replace the 50 amp with a new cable made up with 6/4 SO cable. Mine is 40' and not only noticeably lighter, but far more flexible.
Acampingwewillg
You probably have a Marinco type Plug that goes into the RV...not a cheap plug to purchase unfortunately but doable. (Marinco is the twist on with locking ring type input).
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund.
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie, Mollie, Elvis, Potter and Rosie Love You! (40+ years in all)
HTElectrical
First you need to state what NEMA connector you have on the end, and then go from there.
2007 Duramax, Cognito 7"-9" Lift,
hblosser
https://www.amazon.com/gp/product/B005SB6ROY/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
2017 Chevrolet 3500HD High Country DRW Duramax/Allison
2015 Montana 3610RL Fifth Wheel
azdryheat
Looks like you got an extension cord instead of a power cord. You could always cut the end off and add the appropriate connector to it so it works with your rv.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
