โDec-13-2013 12:15 PM
โDec-16-2013 04:08 PM
โDec-13-2013 05:53 PM
azdryheat wrote:
Had a slider in my last, short-bed truck and never used it.
โDec-13-2013 05:41 PM
โDec-13-2013 03:06 PM
โDec-13-2013 03:00 PM
โDec-13-2013 02:54 PM
newman fulltimer wrote:
b&w has a new slider i would get it if i needed a slider.
tweetys has it is a companion slider 1300.00
โDec-13-2013 02:50 PM
I had an extended cab, short bed Chevy pick up (01'), and hit the left top side of my cab and put a dent in it making a sharp curve....
I know on my 5'r with the relieved corners, even with my SuperGlide, I have had situations where the front corners have come real (within 4 inches) close. I will say however, that since I have the SuperGlide I really don't worry about it. But when in a sharp backing turn or a tight u-turn, I do notice how close the front corners come. I really think if I had to do it over again, I would buy the SuperGlide.
I have used this same hitch on 3 different trucks. The Sidewinder will perform the same benefit. And it works fine. But chances are when you replace your trailer, you'll need a new Sidewinder. When all costs are considered the Sidewinder may not be all that much (if any) cheaper.
All that being said, I would rather have the SuperGlide than a Sidewinder. And a Sidewinder rather than a manual slider. And a manual slider rather than no slider.
โDec-13-2013 02:48 PM
newman fulltimer wrote:NC Hauler wrote:newman fulltimer wrote:
With the newer pinboxes slider hitches are not needed unless you plan on doing alot of tight turns.you can go with a patriot for less than half the price .
you can get one from the chrome shop or tweetys
There are still short pinboxes on 5er's...I see just as many with short pin boxes on dealers lot's as I do seeing 5er's with extended pin boxes.
....I was making a left turn when I hit the top of my cab with the 5er......
how did you hit the cab making a left turn with a longwheel base truck?
โDec-13-2013 02:29 PM
โDec-13-2013 02:20 PM
โDec-13-2013 01:57 PM
โDec-13-2013 01:48 PM
rayeckles wrote:
Do I really need a slider hitch for my ram 2500HD diesel 4x4 short bed pulling a 15k max loaded trailer. this new 5th wheel has the new front end of the trailer 80% turn ratio's.
โDec-13-2013 01:26 PM
โDec-13-2013 01:20 PM
