8'6" width concerns
RVcrazy
Hi All,
If you are towing a 5th 8'6" wide, have you run into trouble? Would you purchase a wide unit again?
34 REPLIES 34
JohnBoyToo
wouldn't you get used to it just like with anything.... ?
after all, it's for "recreation" - enjoy !
realter
Don't know about 5 ers or RV's, but when I had a pontoon that was 8'6", I hated pulling that. Looking in my mirrors, I was either over the center line, or on the white line on the edge of the pavement.
gerrym51
RVcrazy wrote:
Hi All,
government definition of wide load is OVER 102 inches
sele
never had an issue in 9 years, but there is a bridge across the mississippi river at Lousiana Missouri that I avoid like the plaque. Most everybody else I know avoids that Old iron bridge, guys pulling a boat down to the Ozarks any type of camper. I have meet another rv on that bridge we both were going about 20 mph and glad to get by. Couldn't imagine a semi.
scott
travelnutz
Lucky for me that my toy barn has a true 14' wide main door opening. I'll be in great shape when they increase the legal vehicle width the 12'. Bet I'll have a long wait! Unfortunately, my toy barn will probably fall down due to old age before 12' becomes legal though but I'll just wait and hope!
Let's see, 12' vehicle width plus a 4' slideout on either side looks like an 20' wide RV to play around in. OR Maybe they will perfect the slide in a slide system they're now working on and then I'll have a 28' wide RV. A real home on the run! GO GO GO
A superb CC LB 4X4, GM HD Diesel, airbags, Rancho's, lots more
Lance Legend TC 11' 4", loaded including 3400 PP generator and my deluxe 2' X 7' rear porch
29 ft Carriage Carri-lite 5'er - a specially built gem
A like new '07 Sunline Solaris 26' TT
punomatic
travelnutz wrote:
Why, pray tell, would a width of 102" (8-1/2') VS 96" (8') matter when on the road or in a CG?
It probably wouldn't. On the other hand, I have a MH that is 96" wide. My RV garage door is 10' wide. The mirrors clear the door by about 2" on each side. If I got a "wide body" (102" wide) I suspect that I would have to remove the mirrors to get in my garage. There are considerations other than on the road or in a CG.
DW and Me
2016 Riverside White Water Retro 195
2014 Nissan Titan SL Crew Cab
Formerly, I used to work for the department of redundancy department.
Life in Black and Blue
jims1
I never have an issue towing our wide CarriLite. Its narrower than the mirrors on my truck when flipped up. If there legal then the 5'er is.
Volvo dually Pickup
DRV Memphis
Me, Alie, and Salie
Fulltiming
fj12ryder
Has anyone, anyone, gotten a ticket for being overwidth in a stock 5th wheel? Be it 96" or 102".
Howard and Peggy
"Don't Panic"
elliott-Maine
The DOT, at least in Maine, measures the width of a unit by dropping a plumb line from the widest parts of a vehicle and measures the distance on the ground. On a 106-inch unit, if you have an awning you will be over-wide.
Elliott & Vicky, and Hanna, our GSD as the back seat driver
2014 Redwood 36RE, dual pane windows, Onan, and lots more
2013 RAM dually,4x4, Cummins, Aisin
Pete_k
The unreal part, when the company that pics our campers up. They have to get a wide load permit. But when we get it, no permit for over width. Never figured out why that is...
Pete
2022 Ram Big Horn DRW
2016 Eagle Cap 1200
2012 Landmark Key Largo
2005 Chevy Kodiak c5500 Cummins 5.9/Allison Trans
469whj469
I am told that 8 feet is the max in Texas and when I asked how does that work with a few RVs being 8 and 1/2 feet. I was told that they are listed as 8 feet on the title and no one asks any more questions. I have never met anyone who has ever had an issue, even with the DPS.
wandering1
That hasn't been a problem that I know of since 1970.:S
HR
rupprider
An extra 3 inches (from center-line) in trailer width may be noticed in a tight turn. -Assuming a fifth wheel- Check your king pin to back of cab distance.
Tom_Diane
fj12ryder wrote:
Suppose you only had 6" clearance on a side in a construction site with the 102" trailer. If you decrease the overall width to 96" you get 50% more clearance on a side. Another way of looking at it. ๐Ÿ™‚
In the scenerio you give, you would not be allowed on that road with a trailer wider than 8'. in fact, it would be closed it would seem.For what its worth, a standard low boy trailer can be 8' to 8'6. Any wider than 8'6 and you better have your oversize load flags on and the red flags where needed and a D.O.T. premit. I doubt you would run into a situation where loads 8'6" are prohibited but if there was a restriction, I beleive it would be 10 ft or wider, other than that there might be a restriction for oversized loads and 8'6 wide is not an oversized load. Several years ago I was taking a wide load thru Omaha and they were doing construction on the interstate. I was routed by the DOT around the construction. It was a 10 ft restriction and my load was pusing 10ft wide and I got my permit at that width. I missed my exit around the road work and was left with no choice but to go thru the contruction site. I went thru with the flow of traffic and had no problems and I had a 5 axle trailer so I was long as well as wide. What I did was against the law but I had no choice and nowhere to turn around. I didnt get caught but it just reaffirmed that you get some grace on measurments on overhead bridges and narrow bridges and such but doesnt mean you can violate the law. But an 8'6 trailer or RV wouldnt bother me on a standard road way whether in cg or on the road. I guess my confidence is higher than some but I have driven proffessionally and many ,many oversized loads on diferent road construction sites
