AC easy start.
grizz272
What is the best easy start module to add to your ac so 1 honda 2200i generator can run it>
16 REPLIES 16
grizz272
philh wrote:
grizz272 wrote:
Looks like the Micro-air Easy Start is what I am looking for.
Make sure you order the installation kit with it.
I plan to.
philh
grizz272
SugarHillCTD
The Micro-air Easy Start reduces the A/C unit compressor LRA (locked rotor amperage) that draws a huge amount of power on start-up that smaller generators cannot produce.
Once the A/C unit is running, the power draw greatly decreases.
A quick Youtube video explains this-
https://youtu.be/rCjFBhDy9QI
John & Cathy
'12 Chevy 2500HD CC 4x4 sb
'16 Cougar 25RKS w/ Andersen rail mount
'13 Eagle Cap 850 (sold). B4 that a few other TCs and a TT
philh
Westinghouse 2500 watt, tripped the breaker and would not run my 15k A/C
Added MicroAire EZ-Start, and it runs it fine.
Make sure you order the installation kit, I failed to and it make it a bit more time consuming to install
Braces
My 15,000 AC runs well on my Honda 2000 generator ( which is 6 yrs.old )since I installed the Microaire Easy Start. Don't remember AC mfg or model but it came on Montana HC 2014.
Mike134
ksg5000 wrote:
If your talking about a Hard Start Capacitor I use a Supco spp6.
The soft starter he's looking for slowly brings it up to speed rather than "throwing it across the line" with the corresponding dip in voltage we all notice when the lights dim.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
94-D2
As stated, it will start and run. The two stage way is better than the whole draw. But the 2200 is going to run at the highest point on its spectrum and will over tax the generator. I would suspect you could run it to damage in an hour or two, if that. Get a 3 or 4 k generator to do this. A second 2200i will set you back $1,000-1,200. And you get 4400 with options. A broken 2200i will just cost you the same and leave you without.
2018 Ram 3500 Crew Cab Laramie 6.7L, Aisin, air ride, Ram puck prep, SuperGlide 20K auto slide.
2018 Bighorn Traveler 4 slide w/Apt.
Itโ€™s not what youโ€™ve done that commands respect, itโ€™s what you do.
Happy Campinโ€™
Yosemite_Sam1
The issue maybe your generator. Reasons they got two Honda's, lol.
I had a genny with start up at 4,000 and drops to 3,500 on steady run where my a/c draws 2,000.
And yet it still trips and more frequently when it's running on oxygen-thin high elevation.
GPG52_
Sorry, I'm a layman especially when it comes to electricity.
QUESTION: Would it not be just as easy to start up as follows
1- turn your AC Temp knob all the way to a point where the ambient temperature would not trigger the AC to run. i.e. if the ambient temperature was 70 then turn the AC to 80 degrees then
2- start your AC fan only... wait a few minutes with the fan only running
3- then turn your temperature knob down until the AC kicks in.
This way you have a two stage draw on the generator, would that work????
GPG
GPG ๐Ÿ™‚
2014 Ford F250, 6.2L, 4.30 Ratio, 6 speed
2014 Cougar (by Keystone) 327 RES
94-D2
It will run it with a high start capacitor but with the 2200 it is at the top end of its capability and would not recommend that. That generator will not last long because it is over working. I have a Coleman Mach 8 15,000 btu with a high start capacitor. Runs hard with the 2200, perfect with a second in tandem.
Happy Campinโ€™
Super_Dave
Will it allow a 2,200 watt genny to power a 15.3 AC? I thought only the polar cubs could run on the 2,200 watt generator.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
ksg5000
Kevin
MNRon
I donโ€™t have it, but believe the MicroAir Easystart kit on Amazon to be the โ€œbestโ€ but not cheap ($300). Not sure that that will guarantee you can run your AC on a 2K genny though, especially if at any altitude.
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
