โJun-11-2013 06:52 PM
โFeb-24-2016 10:32 AM
skipnchar wrote:
My suggestion is to use a manual switch to turn them on when they're needed. At the same time set up your back up lights on your truck with a manual shut OFF switch so you can actually USE the lights on the trailer. Back up lights reflecting off of the front of the trailer will KILL your night vision making the trailer back up lights next to useless. You'll be surprised how much difference it makes to get rid of the trucks lights when backing.
โFeb-24-2016 07:22 AM
โFeb-24-2016 04:59 AM
banjo wrote:
I have added reverse light to two trailers. Mounted the lights on the back bumper. One wire to ground the other to the center conductor
of the cable. Both of my trucks used the center conductor as reverse lights. You can check your truck with a meter. Center pin should go to +12 when truck is in reverse...
Atom Ant wrote:
Use the relay that comes with most driving lights and power the lights from the camper battery, but switched by the pickup reverse lights though the pigtail. I had four 55 watt halagon backup lights on my old rig, two out the back and two out the side. Great for rolling in at night. Also consider high lumen LED which would eliminate the need for the relays.
โFeb-24-2016 04:52 AM
โFeb-24-2016 04:18 AM
wbbeesley wrote:
going to add reverse lights to my trailer this year. My thought is to use the white led strip lights used on the back of pickups. it is self sticking, low profile and bright. I am considering wiring off a switch so when parked and disconnected from the truck I can use the lights for seeing behind the camper during the stay. I will run a hot line to camper system and install a switch either outside or right inside the camper door.
โFeb-24-2016 03:58 AM
โJun-16-2013 05:24 PM
โJun-16-2013 10:36 AM
โJun-13-2013 05:53 AM
Splashers3 wrote:Side docking lights are standard on some motorhomes, which are not different than what I had. Only on the forum does a simple solution become complicated and twisted. :R
AAnt...I'm sure your fellow campers thought those 55W Halogens were great when you came rolling in the night too....
A friend of mine has 2 Halogens, and he turns them on seperately.They are angled to be less intrusive to fellow campers....2 out the side seems to be overkill.
โJun-13-2013 04:41 AM
โJun-13-2013 03:00 AM
โJun-12-2013 05:23 PM
โJun-11-2013 10:51 PM
โJun-11-2013 08:38 PM
