Air brakes
butkus51_
The more I use my 5er air brakes during a long windy, downhill run, the more touchy my air brakes become. In other words, when I use my air brakes often they engage with a little more force. Before I leave on the original trip, I always test my air brakes that they will stop me in a matter of 10-15 seconds. Air brakes do not lock up and skid the 5er.
19 REPLIES 19
Allworth
Electric/Hydraulic disk brakes are a proven system that gives superb trailer control.
Why reinvent the "wheel"?
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
jaycocamprs
Traveler II wrote:
Even though Iโ€™ve never heard of air brakes for a fiver, the idea is kind of intriguing. Having a compressor could be used to operate the slides, the self-leveling system, or the brakes. Semi trailers have air brakes, so this might be a good idea.
An air over hydraulic brake system is fairly simple. A air brake chamber works the master cylinder. But you have to have a truck that has a air brake system. If you don't have air brakes on the truck, then there are electric over hydraulic systems that are also available.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
RBabb
Manual on my brake controller (prodigy) says to readjust after brakes have been used a couple times to get to temperature. As another post mentioned they build some heat and things swell a bit.
08 Ram 3500 Big Horn, DRW, Crew Cab, Long Bed, 4x4, 6.7 CTD, 6sp Auto, B&W Companion, Prodigy Controller
08 Ram 2500 Big Horn, SRW, Crew Cab, short Bed, 4x4, 6.7 ctd
01 NUWA 39SUT Packrat, 40' Toy hauler- sold
2000 Winnebago Ultimate Advantage 36c
8ntw8tn
I, too, have a Pac Brake on my Dodge diesel. It works really well on downgrades, especially when I've put the tranny in Tow Haul.
'08 Chevy Silverado 3500 Duramax;
'10 Carriage Cameo F35FWS
Det 1 56th SOWg
jims1
KD4UPL wrote:
WyoTraveler wrote:
KD4UPL wrote:
As a former truck driver I can tell you that air brakes shouldn't be used frequently. That's a good way to run out of air. Less applications for longer durations are preferable to lots of short applications. Further, you should be using gear reduction and engine braking to do most of your deceleration.
What TV and FW are we talking about?
In post he said 98 Volvo with Cummins towing 36' TT or 5er
Where did you read that?
I have no clue how all that got put together. As the 2nd poster to the thread, I have a '98 Volvo truck I pull my 5th wheel with. People are reading what they want and assuming a whole bunch.
As for the OP, PacBrake makes an exhaust brake for your setup. Works great, I had one.
Volvo dually Pickup
DRV Memphis
Me, Alie, and Salie
Fulltiming
Traveler_II
2011 Cameo 34SB3
2014 Ford 350 King Ranch, Trailer Saver BD3 Air Hitch, Mor/Ryde pin box, IS Suspension, Disk Brakes
Nights Camped in 2012 - 142
Nights Camped in 2013 - 186
Nights Camped in 2014 - 185
Nights Camped in 2015 - 231
Nights Camped in 2016 - 162
ScottG
rhagfo wrote:
ScottG wrote:
Any chance you can get an exhaust brake fitted to your Cummins?
Some early have issues with exhaust brakes, but can be over come. I seldom use the service brakes on down hill grades EB only!
Oh ya, I forgot about the valve springs and trans not locking up.
KD4UPL
C-Bears
Depending on what kind of grade you are talking about will dictate the best way to handle it with a diesel TV and fiver.
Unless it is just some rolling hills I won't use cruise control.
Always stay in tow/haul mode when towing.
If it is a moderate grade I will limit the max gear available. In my Ford 6-speed I can toggle down for example so that the transmission only has 3 or 4 gears to use, locking out 5th and 6th.
If it is a extremely steep grade I will use my transmission in strictly manual mode. What gear I lock in depends on speed and how steep of a grade.
The bottom line here is what others have said, and it is really not much different weather you are talking about electric brakes or air brakes. Let the engine/tranny keep your speed where you need it, not the brakes.
I am towing around 16,000 and have only experienced a couple really steep long grades out west that I had to use some brake. When I do I only get on them for 4 or 5 seconds to take a few MPH off and then stay off of them. If you ever experience total brake fade you won't want to have it happen twice.
2014 Montana 3725RL (Goodyear G614 Tires, Flow Thru TPMS)
SPENDING THE WINTERS AT OUR HOME IN SW FLORIDA. THE REST OF THE YEAR SEEING THE U.S. FROM OUR LIVING ROOM WINDOW!
rhagfo
ScottG
RAS43
The more that the brakes are used the hotter they get along with the drums. This will reduce the gap between the shoes and the drum which can cause the brakes to sometimes engage harder. Until they get hot enough to fade, then they don't work well or not at all. Better to follow the good advice here about using gearing and save those brakes.
Just_Wandering_
I pull a 34ft 5th wheel, with the ram 2500 cummins. If you use your exhaust brake you shouldn't need that much brakeing on down grades. Are you useing your tow haul and exhaust brake?
WyoTraveler
