Mar-08-2016 09:32 AM
Mar-08-2016 01:27 PM
N-Trouble wrote:ramgunner wrote:
It would be great if they could make a replacement pin box with their system built-in, get it "type-accepted" by the manufacturers, and have it offered as a factory option. I once heard they were working on that.
Sounds like a good idea however if you were stuck somewhere and needed to have your trailer towed your kind of out of luck. Unless someone else happens to have an Andersen.
Mar-08-2016 01:23 PM
Mar-08-2016 12:23 PM
minnow wrote:
Wonder how long it will take for these to be available ? Just checked their web site and they still have the older model as being the only one available. Bet there is a lot of the old stock out there and who will want to buy yesterdays engineering when a better, beefier upgrade is available.
Mar-08-2016 11:45 AM
Mar-08-2016 11:43 AM
Mar-08-2016 11:42 AM
Mar-08-2016 10:52 AM
SkiSmuggs wrote:
Sounds like they have no problem listening to their customers or improving their product. This is the 2nd resign of the ball mount model, first from steel to aluminum and now this one.
Hmmm, with the funnel on the adapter, I wonder if we can upgrade just that piece?
Mar-08-2016 10:39 AM
Cummins12V98 wrote:
Sounds like they must of had some problems with people towing heavy. Looks like it still sits on top of the bed corrugation and will allow for bed deflection unless you add spacers to fill the void between hitch base and top of bed cross member. B&W 18K Companion had that problem with towing heavy until they came out with spacers. My 18k Companion did cause bed deflection towing heavy until the spacers were added.
Does the "IMPROVED" Deaux allow for the ability to lock the RV to the hitch?
Sounds like the original "Ultimate" was not. Is it now?
Mar-08-2016 10:25 AM
Mar-08-2016 10:14 AM
Mar-08-2016 09:55 AM
Mar-08-2016 09:48 AM
