Average pin weight?
mdamerell
I've often read that a 5'rs pin weight, on average, is 20-25% of the trailers weight. Personally, mine runs around 22%. Do most people find this rule of thumb to be accurate?
Reading a thread on 1/2 ton towable 5'rs, the one person posted his numbers and his pin weight was around 16%. Got me to wondering if the 1/2 ton 5'rs run a lighter pin weight? Since most 5'rs will hit the pin weight limit before the tow limit. Is this one way the manufacture's are making them towable with a 1/2 ton truck?
Don't want to start a war, just an honest question.
2012 Sundance 3100RB w/Reese Goose Box
2004 Ford F350 6.0 L PSD, CC, DRW, long bed, B&W drop ball hitch, Firestone Ride-rite air bags.
30 REPLIES 30
rhagfo
goducks10 wrote:
If it handles good it's not really important whether it's 15,20 or 25% IMO.
Mines right at 20% but it just worked out that way, in other words good designing from the factory I guess. From everything I've read the recommended pin weight is supposed to be between 15-25%. I don't think anyone's breaking the law by not having 20%:)
X2
I would believe that smaller lighter 5er would run a smaller percentage as they have smaller basements, in a larger 5er, many load a lot of "Stuff" in the basement ahead of the axles.
JohnD222
2Hams,
Your point about the extra mattress (and pin) weight is right on. It reduces the "tail wagging the dog" affect from too heavy of a tail versus pin. If your setup travels well on (1) down hill curves and (2) mild zigging and zagging between lanes, don't worry about it. If either is white knuckle experience, moving a little weight forward will help, sometimes a lot.
Within reason, I think it would be safer to slightly overload the tow vehicle than have too heavy of a tail that can toss a tow vehicle around pretty easily in an emergency situation.
goducks10
There is physics involved that 20% figure is designed to give optimum performance and stability. 20% does not happen by accident or chance. But most fivers are designed that way.
If your tongue/pin is too light there will be stability issues. Unfortunately the driver may not find out until there is some type of incident.
Recommended pin weight according to all the literature I've read can be anywhere between 15-25%. Show mw where it has to be 20% or more. Every trucks owners manual I've ever read always says 15-25%.
That's not to say that every 5'er will react the same with the same pin weight. Some need more, some don't.
2hams
The posted 16% pin weight was from a CAT scale weigh, so it is not wishful thinking. As for loading, tools, bottle jack, Coleman grill, chairs, awning screen all in basement. Also in front of axles - residential mattress and 4" memory foam topper and the pantry. Only heavy stuff in the back are essentials like a case of beer and 20# of dog food. 🙂
Maybe because there is no bedroom slide?
Also it tows and rides better since we changed the mattress.
2019 Grand Design Solitude 310GK
2019 GMC Denali 3500 D/A SRW
JIMNLIN
Our first 5er had a 17 percent pin weight. It pulled beautifully by itself or with a 3400 lb boat behind it.
2nd 5th wheel trailer had a 20-22 percent pin weight and it towed like a sick hog on ice.
Current 5er has a 19-20 percent pin weight. Zero towing issues with it.
The industry tells us a 15-25 percent is recommended.
I pull GN equipment and a 36' tri axle stock trailer which can be loaded at any percent hitch weight. I pulled 18k GN trailers with around 12-13 percent on the ball and no issues.
Half ton towable ?? Our 1/2 ton trucks run from a 6xxx GVWR with small 3500 rawr/P tires and 1500 lb payload up to 8600 GVWR and 6000 rawr/E tires and wheels with over 3000 lb payload.
cdlaine
Loaded for fun... 21% (per CAT scale)...but I've never
been perfect.
Charles
2003 2500HD, 8.1L,CC,4.10,2WD,Allison
Standard bed
Ride-rite air bags
Prodigy
Husky 16K sliding
2013 Artic Fox 29-5T Silver Fox Ed.
Pin wt.(CAT Scale) 2660#
5th (Cat Scale) 12600#
I'll want the Frim Fram sauce with the Ausen Fey with
Chafafa on the side.... Nat
banjo
I am at 20.6%
Banjo
2011 3500 DRW D/A CC LB 4X4
2011 Cameo 34SB3
fj12ryder
Both our '03 Big Sky and our present Fuzion toyhauler show 20% on the pin when I weighed them loaded and ready to travel.
Howard and Peggy
"Don't Panic"
NC_Hauler
Last I weighed , this past March. 5er weighed in at 16,050#, pin weight was 3330#. Pin weight of 5er is 20.7% of 5er weight.
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
Lantley
Rob_Fla
Our loaded weight is 15,200 lbs and our Pin Weight is 3,400 lbs
That puts us at little over 22%, about where I would expect to be.
2014 Redwood 38FL
2018 RAM 3500 DRW
goducks10
12thgenusa
romore wrote:
If his pin weight is 16% it is a product of
1. wishful thinking
2. poorly loaded with too much weight behind the axles
3. a poorly designed trailer with the axles too far ahead.
Our 24.5' without a slide grosses at 5600 lb, pin weight comes in just shy of 1300 lb which is pushing the limits of any F-150/1500. Such a truck will pull it, many people do, but the experience would not be enjoyable or safe. We started out with a truck that was marginal for our needs, won't make that mistake again.
None of the above. Here are the numbers from my last weighing:
Trailer GVW: 8100
Pin Weight: 1240
Pin Weight %: 15.3%
I've towed this combo up and down and all around the Colorado rockies for over 10,000 enjoyable miles. This is a 26 ft. rear kitchen with one slide.
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar, Victron BMV-712, Victron SmartSolar 100/30, 200AH LiP04 bank, ProWatt 2000.
azdryheat
Most people never weigh their trailers so we'll never know the answer.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
therink
My fiver loaded scaled at 12,280 with pin at 2400. Just shy of 20%.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
