bedroom slide will not go out
smarty
Checked the fuses all are good
Any easy peezy fixes I am not thinking about
Lippert slide system, kitchen slide works fine
It almost seems like one side wants to work while the other does not
9 REPLIES 9
smarty
thanks everyone for your suggestions, will start digging around this weekend
very much appreciate your guidance
ChuckSteed
OP ..
Do you have electr8c or hydraulic slides? If electric look for a resettable DC breaker for that slide motor...
If hydraulic and other slides are working then Iโ€™d be looking at solenoid valve for that slide actuator.
ACZL
Perhaps a bad breaker or 2?
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
JD38
I have found that low fluid is the most common for me try adding a bit AT THE MOTOR not the resevoir
Joe and Phyllis
FourWinds Windsport, 35D
2003 Liberty
๐Ÿ™‚
R12RT
There are two motors driving the Lippert slide out. One is not working. You can switch the connections on the controller located maybe on the basement ceiling. Lippert has some videos on this system that should help diagnose the problem. I googled "Lippert schwintek video" and got quite a few hits. Is it stuck with slide in or out? It could be the motor or wiring or the controller. Good luck.
garyemunson
Lipperts have a controller somewhere with diagnostic lights. Often on the 'ceiling' in a storage compartment under the slide.
http://www.primetimerv.com/download/ComponentManuals/Chassis-Lippert-MasterComponentManual.pdf
Merrykalia
Could it be that you are low on hydraulic fluid? Ours will do that if for some reason it's low. Take a look at it.
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
RedRocket204
When you hit the switch for the slide that ins't going out, is there any noise created like a motor is running? As the previous poster mentioned, something like that could be a shear pin. You obviously have battery otherwise the kitchen slide wouldn't work.
The slide in my trailer had a fouled ground. I traced the ground wire back from the motor and found where it attached to the frame. The ground wire to frame connection was very loose with some rust where the connection should be touching metal. I sanded the frame down in that small area, added a new lock washer and really tightened the bolt down to the frame. Hasn't been an issue since.
I love me some land yachting
kampinguru
possibly a shear pin or stripped gear in the gearbox that the motor drives.
2000 F-250 S/B 4X4
2005 Cedar Creek 30RLBS
Pullrite Superglide 16K
