Aug-02-2017 08:16 PM
Aug-04-2017 02:53 AM
Aug-03-2017 08:12 PM
tinner12002 wrote:
I've wondered about how often that happens after seeing how low those jacks hang down behind the rear tires. Some are even several feet behind the tires.
Aug-03-2017 08:10 PM
djousma wrote:Fulltimer50 wrote:
The jacks on my rig are set at a 5* angle by design. Unless yours is bent more than that, I would not worry about it.
Mine are two, but outwards, for stability I presume. I expect that the OP's is bent forwards from backing into something. OP also doesn't say what part is bent. Since it was most likely fully retracted, the piston probably isn't bent. Could you possibly just loosen the bolts that attach it to the frame, and just see if it moved vs actually got bent?
Aug-03-2017 07:35 AM
Aug-03-2017 07:18 AM
Aug-03-2017 03:06 AM
Aug-03-2017 02:50 AM
Aug-02-2017 08:19 PM
