โJun-19-2013 11:07 AM
โAug-03-2013 08:25 PM
โAug-03-2013 08:16 PM
โJun-29-2013 08:02 PM
โJun-29-2013 07:24 PM
โJun-27-2013 06:48 AM
โJun-27-2013 06:19 AM
โJun-27-2013 12:18 AM
mapguy wrote:64thunderbolt wrote:
probably not much diff in cost . So go big & be comfortable. I would have done the same.
If OP's axles were T60/D60 AlKo "go big" in this case would be 2 more lug nuts and a slightly larger outer bearing. The original drums would've handled a 7k brake lining -if they weren't already 7k rated friction material.
Biggest thing is getting rid of the questionable capacity 15" size stuff.
Hope the OP has luck getting some reimbursment from OEM.
โJun-26-2013 01:11 PM
BobWanderer wrote:
I fully understand the offset differences, it would only be used if I had a second tire failure or 2 at once and only to get to a tire shop.
I have an extra spare for both truck and trailer as it is, so it doesn't matter to me.
โJun-26-2013 10:53 AM
โJun-26-2013 08:12 AM
โJun-26-2013 07:17 AM
JIMNLIN wrote:
Trailer wheels and truck wheels have very different wheel offset requirements.
Trailer wheels require a zero offset as the load is carried between the inner and outer bearing. Using a truck wheel with lots of offset can whip a trailers wheel bearing out quick
They also have a different center hole size.
A trailer wheel is lug centered with a big center hole for clearance vs the wheels close tolarance center hole locates the trucks wheel to the hub.
โJun-26-2013 05:11 AM
โJun-25-2013 09:55 PM
Thurbersfolks wrote:
I was told that both are the same bolt pattern and you have hit the nail on the head. Two spares, works great for me. They are Chev bolt patterns. My 3/4 ton has done me well and will keep it til..........Thanks
