Jul-26-2013 08:02 AM
Aug-03-2013 09:06 AM
Aug-03-2013 08:50 AM
Me Again wrote:Slownsy wrote:
Not defensive Chris I do have disks on my fiver from new and newer noticed any delay, you described hove disks are activated and I merely asked if there wasn't the same chain off events with drums, which is old fashioned and outdated, have you ever bean at the bottom of mounted and smelled all the burnt brakes, that is why they developed disk brakes.
I have an exhaust brake on our Dodge/Cummins and would not tow without one. I seldom touch the service brakes descending a mountain pass, so I have nice cool service brakes when required. Using service brakes of any kind descending mountain pass leads to over heater brakes. I drove a 8500 gas tanker years ago without jakebrake on the Olympic Peninsula in Washington, never again! I often smelled over heated brakes!
There is now only one top tier aftermarket brake controller in the MaxBrake. Earlier there was the BrakeSmart and Jordon. All three are head and shoulders over controllers like the Prodigy!
Someone early posted 1 second delay for disc brake pump. At 60 MPH that is 88 feet, which is quite a bit of distance.
Chris
Aug-02-2013 11:01 PM
Me Again wrote:sheff69 wrote:recycler wrote:
i would see about upgrading your wiring and installing new drum system is lots cheaper and easier to maintain..
It might be, but it is nowhere near as efficient.
In over 30 years and numerous trailers, with reasonably heavy trailers, I've never been able to lock up drum brakes in a panic stop.
With my Kodiaks, I can. I'd rather flat spot tires than repair damaged truck front ends.
I've always maintained my own brakes, and I'd much rather work on greasing slide pins on disk brakes, than trying to adjust drum brakes.
Sheff
Sheff I believe if you research it, that max braking occurs at a point just before the tires lock up and skid. Once the skid starts breaking power goes down quite a bit. That is why modern cars and trucks have anti lock brakes, plus the handling issue.
I trailer with locked up brake is more likely to come around on you and flip on it's side.
So lock up is not GOOD!
Chris
Aug-02-2013 06:11 PM
Aug-02-2013 05:25 PM
TheAmRheins wrote:
Cummins12v98 when installing the Kodiak brakes check the stud bolts in the hubs and make sure they are seated properly.I didn't and I had one hub that I had to retorque 6 or 7 times
Aug-02-2013 04:32 PM
Aug-01-2013 07:47 PM
Aug-01-2013 07:31 PM
Aug-01-2013 06:28 PM
Aug-01-2013 11:51 AM
Aug-01-2013 10:57 AM
Aug-01-2013 08:52 AM
Sheff
Aug-01-2013 08:51 AM
TheAmRheins wrote:
I must say that with the maxbrake and disc brakes I have no delay. And those I have spoken to that did have fixed that by bleeding their brakes again.
Aug-01-2013 08:37 AM
Jul-31-2013 08:07 PM
