coiled breakaway cable for 5th wheel
D_E_Johnson
Has anyone used the coiled breakaway cable? Our regular cable has gotten stuck under the hitch rail at least 2 times. Its a bugger to get out when you are traveling and it gets damaged. We are going out today to look for the coiled cable.
Need your expertise on this product.
Thanks, Dona
Dona and Elvin
2010 Dodge Laramie 3500 4x4 Mega cab-in Pearl black/tan
2007 Open Road 359RL3S
2004 Yamaha Kodiak 400 ATV
29 REPLIES 29
rattleNsmoke
I have mine clipped to the hitch handle too. I replaced the straight wire cable with a 4ft coiled breakaway assembly after I found the old one was burnt out and wouldn't lock the brakes anyway.
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
Krease
According to ALL the dot inspections I've had (GA,SC, TX, LA, FL and TN) it is NOT legal to attach your breakaway to the actual hitch. Attaching it to the bed or mounting rails is the correct way to do it. With that being said... if you're not commercial, you are not likely to ever get inspected unless there are other obvious safety issues while you're rolling down the road.
This coming from a commercial RV hauler. You don't have to play by the rules, but I do.
2011 Ram 3500 Longhorn H.O. Megacab DRW
2012 Montana 3750FL
anaro
SEMO Mike wrote:
On my B & W hitch I put the loop through the pin which locks the handle in place.
This is what the dealership taught me to do. I was feeling uncomfortable with it knowing I hooked to the same place I hooked my safety chains on my old tt. I might try using my left rear tie down to hook to also.
2014 Silverado 3500 Duramax, SRW, Crew Cab, 4WD
2014 Palomino Sabre 34REQS -
2011 Crossroads Zinger ZT26BL - sold in 2014
4advtr
I do the same thing.
2014 Redwood 38BR
2013 Ford F-350 6.7L SRW
B&W Turnover, 18K Companion
SEMO_Mike
Tin_Pusher
LOL @ MileHigh
Tin Pusher's Guide To Successful RV'ing: "Don't get mad, don't get in a hurry"
2002 1500HD
2002 Wilderness 265H
1997 Seadoo GTI
1952 Wife;)
Furch5263
Tough crowd
Todd
Mile_High
Tin Pusher wrote:
OK, so the WHOLE BED comes off, what then? :B
Ya, that's what happened to me ๐Ÿ˜ž
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
Tin_Pusher
Well, I am going re-visit this practice, but no promises ๐Ÿ™‚
2002 1500HD
1997 Seadoo GTI
1952 Wife;)
Furch5263
Sorry just got your post! Exactly i like it. Thanks greatly appreciated.
Todd
Furch5263
The pusher, i through mine over the same thing but from what i have read and or heard it is supposes to be seperate from the hitch attached to a part of the truck in case god for bid the hitch came out with the trailer. The brakes may not come on it the cable never got pulled. Was actually thinking if putting an extension and attaching it to the front left tight down loop in the front if the bed. Or use the coil one with an extension if its not long enough.
Todd
ependydad
Tin Pusher wrote:
2112 wrote:
It kind of defeats the purpose if the hitch breaks loose.
Yeah, a few seconds thought AFTER posting lead me to the same conclusion :S
But, really...
If the king pin and/or broken hitch exit the bed far enough to pull the break-away, hits the road and the whole thing goes a$$ over tea-kettle, how much help are the brakes going to be?
(Hope none of us ever has to find out :))
Truly, you *should* hook the breakaway cable to a part of the truck. I use the rear corner tie-down for mine. It's right next/below my in-bed 7-pin connector, so I just do them both at once.
But I have the same view as those who connect to the hitch; if the hitch is coming out of the truck, there are forces violent enough that it is going to pull the breakaway cable, no doubt. Connecting to the hitch should be plenty good enough.
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
jaycocamprs
Here is my setup.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
remdog_1
I went to the coil type after accidentally pulling breakaway on a sharp turn after leaving campground. I hook my cable to the tie down in pickup bed, don't hook it on any part of 5th wheel head. The reason for this is if hitch does fail, the breakaway switch will not be pulled. Same thing on rear bumper type hitch, hook breakaway cable to the vehicle, not the hitch or safety chain.
