I would stay away from the second one, if only for the problem with the roof. Doesn't sound like it has been taken care of, so other problems may pop up. If the first indeed only needs tires, that's a relatively small, and expected, issue to deal with. That's the one I would be checking out further. Good luck!
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
