โMar-14-2014 10:13 AM
โMar-17-2014 08:28 AM
โMar-17-2014 06:41 AM
cmoecmoe wrote:
Can you use a lube plate with a SuperGlide???
Craig
โMar-17-2014 06:36 AM
โMar-16-2014 10:12 PM
โMar-16-2014 07:05 AM
โMar-16-2014 06:53 AM
ventrman wrote:NWKomfort350 wrote:
I use one and grease the pin.
I am fairly new to the 5th Wheel World. This one was delivered for us. I have never towed one. What Part of the Hich is the Pin?
โMar-16-2014 06:48 AM
โMar-15-2014 02:17 PM
โMar-15-2014 12:11 PM
R12RTee wrote:FSJPat wrote:R12RTee wrote:
I found the hitch pin lube plate to be a PITA so I had a better solution installed on the hitch. Works great and never falls off.
Just curious, but how is something that you put on once (that takes a few seconds to pop over the pin) and forget, a PITA?
Maybe if you only use the trailer occasionally they work OK but if you use it often you will find that the disk falls off and the fingers have to be hammered to elongate them so the disk stays in place. The disk also often gets caught between the hitch and the pin and crushes it. There OK for what you pay for them but far from perfect.
โMar-15-2014 11:38 AM
โMar-15-2014 08:22 AM
โMar-15-2014 07:52 AM
ventrman wrote:
How many People on here use one of these? Lube Disk Are they recommended?
โMar-15-2014 05:41 AM
โMar-15-2014 03:05 AM
