โJun-26-2013 09:48 AM
โDec-17-2013 09:49 AM
avvidclif1 wrote:
The OP has a Ford, not a Dodge and he never said if it was a SRW or Dually. Just a 2010 F350 CC LB.
โDec-17-2013 06:52 AM
Atom Ant wrote:avvidclif1 wrote:Doesn't matter what the OP said anymore. This is a resurrected thread and the OP said he already bought a rig and is out fishing instead of typing. :B
โDec-16-2013 10:24 AM
โDec-16-2013 10:12 AM
โDec-15-2013 04:41 PM
โDec-14-2013 07:42 AM
โDec-14-2013 06:36 AM
Atom Ant wrote:NC Hauler wrote:06Fargo wrote:
The rear axle GAWR rating of 6200lbs axle on our SRW truck is the capacity of the 2 Rge E tires. Before I bought 19.5 tires I researched part numbers. Our SRW 3500 shares the same axle, bearings, & springs as a 3500 SLT dually of the same year, body, and equipment. The SLT dually has a rear rating of 9350lbs. The new 19.5 tires have a single rating of 4540lbs each x 2 = 9080lbs so by changing out the limiting component (Rge E tires) I have a set of components which offer capacity to spare.
I don't know if Ford trucks like fairhaven's F350 share components between dually and single wheel versions.
My rule of thumb is be careful with correct loading of components carrying the weight like tires, suspension, hitches, axles.
Don't worry near so much about "tow rating" if you are prepared to operate your vehicle with some common sense, and your trailer has a proper set of brakes and you are comfortable and have some experience with heavier vehicles.
Am I understanding you correctly that your rear axle weight rating is 6200#, and you added higher weight rated tires? So now your "weak link" is your rear axle?? I really wouldn't want to exceed my trucks GVWR, (but that's not real popular to say around here), but I'd think most would also not recommend to exceed one's rear axle weight rating. You stated you had OEM tire capacity that equalled the RAWR of your truck and now you've added higher weight range tires, exceeding your rear axle rating by well over 1.5 tons, is that safe? Do you now ignore the RAWR and figure you can load the truck over your trucks RAWR? Again,I would think that would make your RAWR the "weak link"., I'd be leery of doing that.
But he looked up all the numbers and found out all Dodges use the same parts, just different tires. :R
โDec-14-2013 06:25 AM
โDec-14-2013 06:03 AM
โDec-14-2013 02:19 AM
fairhaven wrote:
Wow, a post of mine from 6 months ago has resurfaced. I ended up buying the fiver in my signature.
โDec-14-2013 02:18 AM
โDec-14-2013 02:10 AM
kglenn wrote:
I have a 2012 F350 non dually short box crew cab with 20 inch tires and tow a 2013 Rushmore Washington model. My hitch weight is around 3500 lbs loaded to camp. My truck tow s this package easily. Feels very safe at any freeway speeds up to 70 mph. Still felt ok at 80 mph but not style. My package is still legal on all axles
โDec-13-2013 09:38 PM
โDec-13-2013 06:49 PM
