โMar-08-2016 05:16 AM
โMar-08-2016 12:23 PM
Padlin wrote:
Soaked everything down with soapy water, no bubbles as far as I can see. Shutoff one of the bottles, will see if it clears up. Can't see the back side of the valve.
โMar-08-2016 12:18 PM
โMar-08-2016 10:48 AM
RustyJC wrote:
Check at the vent port of your regulator if all else fails. Although these regulators will normally vent a TINY amount of gas, if it's that strong and smells strongest around the vent port, chances are the diaphragm in the regulator has split. They're relatively inexpensive to replace. Been there, done that, got the t-shirt to prove it. ๐
Rusty
โMar-08-2016 08:58 AM
BB_TX wrote:
Do you have one of the little red regulator valves just off one of the propane tanks? Those are notorious for developing leaks.
โMar-08-2016 07:54 AM
Padlin wrote:
My FW has 2 20 gallon propane tanks in an enclosed area, there are 2 3" vents down low on the door. With the valves open I can smell gas whenever I open the door. Never having had enclosed tanks before, is this normal or should I have the area tested for leaks. This is not a new thing, it's been like this, probably since I got the trailer in 2014.
โMar-08-2016 07:43 AM
โMar-08-2016 07:41 AM
filrupmark wrote:
If you have a small leak at a pipe thread connection don't use regular white Teflon tape. It will leak. They sell yellow Teflon tape made for LPG . We had issues with forklifts leaking LPG at work . Finally we learned about the special tape for LPG . No more smell or leaks.
โMar-08-2016 07:24 AM
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โข <\br >Toys:
โMar-08-2016 06:39 AM
โMar-08-2016 06:26 AM
โMar-08-2016 06:12 AM
โMar-08-2016 06:10 AM
โMar-08-2016 05:31 AM
GASMAN6674 wrote:
You have a leak.
Mix up some soapy water and paint/spray all the connections and look for the bubbles to grow. Then repair as required.
If you don't feel comfortable with that take to your local LP gas supplier and ask them to check it. But i would call first to make sure they can and are willing to do it.
Good Luck
โMar-08-2016 05:25 AM
