Gap in the 2nd deck moulding when hooked
alcsiobc
I have an Keystone Avalanche 2011 , 38'for 4.5 years now. Like the unit very much.
A problem developed over time, when I hook it the the pickup, the moulding running from the bottom of the second deck down to the landing gear separate itself from the wall. (see pictures) Here we ca see the gap
When I un-hook it return to its place.
Is this normal ? Can it be fix ? Any idea at what cost ? Is this dangerous (I doubt it) ?
I added long screws but didn't do anything...
Claude, QC , Canada
Ram 3500 Diesel, Avalanche 2011
18 REPLIES 18
TXiceman
Frame flex and leads to frame failure. It may be under the chin, but again, it may be a failure in the sidewall frame. The corner where the bedroom slide out is a weak point.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
Snowman9000
That looks like the infamous Keystone/ Lippert front frame failure. These pages had a lot of stories about them a couple of years ago. The fix is to strip off the pin box and lower front area panel(s), and have a welder go to work. If you ignore it, it can fail completely.
One of many old threads
Currently RV-less but not done yet.
pcm1959
I'd suggest dropping the chin of the pin box area and checking for broken welds or frame members. Something is definitely not right - especially if it is worsening over time. Dangerous? For sure if the frame breaks and the rig falls on your bed rails - at best!
There have been a number of post on various forums about fifth wheel pin box frame structure issues. Just my opinion, but I'd get it checked SOON! Phillip
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
spud1957
I am certainly no expert but that just isn't right. Since it has progressed over time that should tell you that something is weakening in the frame when the weight is supported by the pin.
I'd have that checked ASAP before it totally collapses.
S
2018 F350 6.7 4x4 CCSB
2022 GD Reflection 337 RLS
