Jan-25-2014 05:51 PM
Jan-27-2014 02:38 AM
Jan-27-2014 01:30 AM
Jan-26-2014 08:16 PM
Jan-26-2014 06:17 PM
Jan-26-2014 06:41 AM
btd35 wrote:
Listen to Chris. Pull the emergency brake pin with it disconnected from the truck. If they work then check your wiring at the plug on the trailer, or get yourself a 12 volt needle light tester and check for voltage on the trailer lighting. I've had times the truck outlet has power, but the trailer plug did not make a good connection with it.
Jan-26-2014 06:31 AM
fpresto wrote:
Since you said it was intermittent and then went to total failure that does narrow it down. A missing ground is one possibility but a very common issue, especially with intermittent brakes, is how the wires run to the wheels. They usually run down one side or the other and then go through the axle to get to the other side. Unfortunately the inside of most axles is not smooth and the OEMs do not sheath the wires. Normal vibration then rubs bare spots in the insulation causing intermittent shorts and eventually failure. While this might not be your problem it is a very common cause of brake issues.
Jan-26-2014 06:27 AM
Jan-26-2014 05:46 AM
Jan-26-2014 05:34 AM
Jan-26-2014 04:58 AM
Jan-26-2014 01:00 AM
Jan-25-2014 09:37 PM
Tom & Beth
05,Grand Junction 35TMS
99, Dodge 3500 Dually.
Jan-25-2014 07:36 PM
