โJan-27-2014 04:43 PM
โJan-29-2014 04:21 PM
โJan-29-2014 04:11 PM
โJan-29-2014 01:31 PM
Ezbagr wrote:
I came across this towing chart for 2013 Ram 2500`s-here is the link
http://blogs.cars.com/files/8-ram-2500-hd-towing-2013_01-08-13.pdf
According to this chart his truck can tow a trailer in the 16,500-17,000 territory. As other people have said the GAWR of the rear axle will probably be
the limiting factor. Saying that, they show the base weight of the rear axle in the 2700-2800 pound area and the GAWR of the rear tires at 6200 pounds and the GVWR at 10,000 pounds. They also show the total basee weight at 7000-7200 pounds.
So say the base comes in a little higher and when loaded with fuel and ready to go camping the 7700-7800 and say the rear axle is 250 pounds heavier.
So with the real axle weighing in at 3100 pounds he has still got 3100 pounds left for pin weight. Yes he will be over the GVWR but he will be right at his GAWR of the rear axle.
So he may well be able to tow this trailer. He will be over GVWR but most people tend to agree that this number doesn`t hold much water and that you really need to make sure you are not over the rear axle GAWR.
Now don`t get me wrong, he DOES need to go weight his truck full of fuel and ready to go to see where he is at with his weights and also come up with a educated guess on the pin weight but he might be very close to being in specs except for the GVWR.
โJan-29-2014 11:39 AM
โJan-29-2014 06:59 AM
2008Wildcat wrote:quentinlindsay wrote:
I am already well aware of the towing/payload capabilities of my truck as I utilized the manufacturers specs for my truck
I don't believe you.
As I stated, I checked the tow guides, and there is no configuration of your truck that is rated for 17,000 lbs.
โJan-29-2014 05:42 AM
I can do the math!
I am fully confident that my configuration - properly loaded - will be more than sufficient for my truck to handle.
โJan-28-2014 04:27 PM
That being said, I am already well aware of the towing/payload capabilities of my truck as I utilized the manufacturers I utilized the manufacturers specs for my truck along with my background in mechanical engineering to make that determination - So yes, I can do the math!
โJan-28-2014 03:45 PM
โJan-28-2014 02:33 PM
โJan-28-2014 01:35 PM
โJan-28-2014 01:28 PM
โJan-28-2014 08:49 AM
Tow rating for the truck is 17000lbs and change,
โJan-28-2014 06:11 AM
โJan-28-2014 02:43 AM
โJan-27-2014 09:47 PM
