hitch weight
boingram
Hi all...I am looking at fivers in the 10k dry/12.5 gross range.
Which will tow better...hitch weight in 15-1700 or 2-2200 pound range.
2015 gmc denali 3500.
Thx...bo
8 REPLIES 8
Norskeman
I don't have a denali - but my 2011 tows like a dream. Had a 2005 3500 and traded when GM made the upgrades in 2011. My hitch weight is in the 2200 to 2400 lbs range.
I switch to Bilstein shocks at 21,000 miles and added air bags before my first tow. With my rig the rear settles about 1 3/4 inches - just touches the "over load" springs - air up the bags to about 45# and most of the sag is gone. Rides much better with the Bilstein's when towing.
My CAT scale weight:
Steer Axle - 4900 lbs
Drive Axle - 6060 lbs
Trailer Axle - 9220 lbs
Gross Weight - 20,180 lbs
2 passengers in the truck, full tank of diesel (36 gallons) and 1 small dog. Trailer is packed for 2 weeks of camping and about 1/3 tank of water.
Trailer GVWR 12,380 lbs. Add onโ€™ s to the original weight (10,015 lbs) both propane tanks full, dual 12V batteries and 3 slide awnings.
2017 Keystone Avalanche 320RS
TV - 2011 Chevy Silverado 3500HD LTZ CCLB Duramax SRW 4X4
john_bet
Thx...bo
Either will be fine with your truck. My 5er is the same size and I pull with an 11 year old 2500 with all weights within spec's.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
rhagfo
Thx...bo
NO ISSUE!!!!
I tow a 5er with a 9,800# dry and 12,360 GVWR at 11,00# just fine with my 2001 Ram 2500, over the 8,800# GVWR, but well within the 6,084 rear GAWR.
C-Bears
Thx...bo
With a 1-ton GMC you shouldn't have any issues with any fiver in the 10,000 to 12,500 weight range, except your pin should be in the 20% - 25% range. But really much more could come into play. Maybe your hitch weight starts out at 2100 pounds but after loading everything up and going across the scale it is really 2900 pounds.
Really too many varibles to say which one could actually tow better. Probably not much difference.
2014 Montana 3725RL (Goodyear G614 Tires, Flow Thru TPMS)
SPENDING THE WINTERS AT OUR HOME IN SW FLORIDA. THE REST OF THE YEAR SEEING THE U.S. FROM OUR LIVING ROOM WINDOW!
Water-Bug
Always buy a hitch to match the capability of the TV. That way you can always upgrade or tow any trailer that your TV can handle.
ependydad
jims1 wrote:
15-20% of the total weight on the pin is all that matters. And towing as close to level as you can.
I'd actually extend that to 15-25%. I think a 15% fifth wheel is a pretty good rarity.
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
jims1
Volvo dually Pickup
DRV Memphis
Me, Alie, and Salie
Fulltiming
brirene
Won't make much of a difference if correctly loaded, hitched at right height, etc. Your tv should do fine with either.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
