Hot water system problem
MainerBob
I have a gas/electric Suburban water heater in my Everest. When I am boondocking (no hookups) and I turn on the hot water at any outlet, I hear a lot of gurgling, coughing noises coming from the hot water heater and a lot of air comes out of the faucet with much sputtering. After a few seconds I start to get water, the noises stop and the water gets hot and I can go on with what I needed the water for. It happens if I have not used hot water for more than ten minutes or so. It only happens on hot and only on the pump, which was new last year. If I am on city water everything is normal. I have no water leaking anywhere. Any ideas on where to start looking?
2007 Keystone Everest 293P, 32'
2006 Silvarado 2500HD Duramax, SRW, CC, Short Bed, 4x4
Sidewinder,16K Draw-Tite Slider
Chloe, Standard Poodle
Charlie, Tibetan Terrier
6 REPLIES 6
nomad_297
Do you have a winterizing inlet on the outside of your RV for antifreeze uptake for winterizing? If so, you have a valve right at your pump to change over from fresh water tank to winterize. That valve may be only partially closed, Check it and make sure it is turned all the way over to fresh water tank instead of winterize.
Bruce
DirtyOil
A couple of the posters maybe on the right track here. If your not seeing any water dripping or any puddles, you may want check the hot water tank isolating valve(s)... the ones you would close/open to isolate the tank when winterizing the water system. The valve(s) may not be fully closed/opened, or are as posted may be leaking.
If the safety valve is indeed leaking, you will see water dripping/spraying from it or even see steam vapours and/or hear air escaping from the safety.
As asked, do you leave the pump on all the time, if so does it run fairly constant? That'll tell you if you have a leak.
2013 RAM 3500 CTD Crew 4x4 Laramie
2014 Sprinter Copper Canyon 269FWRLS
GUTS GLORY RAM
Old-Biscuit
Do you leave our pump ON when boondocking or do you turn it ON when you go to use water?
With pump left ON..........it would run momentarily every so often IF there was a leak in system due to drop in system pressure.
Temp/Press Relief Valve on water heater would show signs of leaking---scale etc on gas solenoid valves directly below it.
With pump only being turned ON when you use a faucet/toilet then back off water could backflow thru pump back to fresh water tank.
But when on city water fresh water tank should fill up/over fill if pump check valve was weak.
So ........how do you use your pump when boondocking ON or On/Off??
TakingThe5th
Just another guess, but check your pressure relief valve and work it a few times. It might be letting air into the hot water tank as the water cools. Working the valve might get it to re-seat itself.
Why does it only happen with the pump? Maybe you have less pressure with the pump. Or maybe you have a loose connection or a leak somewhere between the pump and the tank which allows the air in when the pump is off.
TakingThe5th - Chicago, Western Suburbs
'05 Ford F350 Crew 6.0 DRW Bulletproofed. Pullrite Super 5th 18K 2100 hitch.
'13 Keystone Cougar 333MKS, Maxxfan 7500, Progressive EMS-HW50C, Grey Water System.
RoyB
You might want to install one of those additional pressure tanks..
They look something like this... Available from LOWES - AMAZON...
I have never had any dealing with something like this but it seems this would at least get a good source of water already pressured up to use...
Might solve the not using the hot water deal you mentioned????
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
agesilaus
Just a guess, if there is a check valve in the hot water line it may be letting water drain backwards when the pump is off. A weak check valve in other words. The question would be where is the air coming from to fill the line. Do you have a dripping faucet?
When you are on city water the high pressure to the pump would keep the line filled.
Someone with a more informed opinion may come up with a better idea tho.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
