How long can 5th wheel stayed hooked up...
zackyboy3rs
To my truck? Arrived back home today (Wednesday) and heading out next Monday. I have taken the load of the truck. Do you think it is ok to stayed hooked up that long?
2009 Chevy Silverado LTZ 2500HD 6.0L, 3.73, Gas sipper
2015 Jayco Eagle HT 27.5 RLTS
13 REPLIES 13
phillyg
No issues in my opinion. If it makes you feel better, extend the landing legs to take the weight off the TV.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
wilber1
When we head south in the winter we stay hooked up for six days. Same coming home.
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
DownTheAvenue
KD4UPL wrote:
You could leave it hooked up forever. It won't hurt a thing.
I'm really not sure why you would ask. What part are you concerned about being damaged somehow?
X2
RustyJC
schlep1967 wrote:
The only problem I could see is if the trailer is not level when hooked up. Are you level side to side and front to back? This only really matters if you are running your refrigerator.
And then only if it's an RV (non-residential) fridge.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
schlep1967
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
Irish2
No problem to leave it hooked up for that period of time. I have done it a couple times without issue. As others have said disconnect power from your truck and hook up to shore power. Good time management I say!!
2013 Winnebago 42E
2019 Jeep Cherokee Trailhawk
Old-Biscuit
Staying hooked up to truck is less stressful on truck then towing it down the roadways bouncing/bucking/jerking/etc.
It is just static load.........moving is dynamic load and much higher strain
You are overthinking it.
SoCalDesertRid1
If you're asking about the truck's suspension, no, there is no issue with leaving the trailer on the hitch all the time. It won't hurt the truck's suspension at all.
As far as the electrical cord, disconnect it so you're not running your truck batteries down, if your truck's trailer charge circuit isn't one that disconnects when the key is off.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
zackyboy3rs
WE-C-USA wrote:
No problem leaving it hooked up. Connect to shore power, with at least 15/20 amp. Unplug harness from truck and leave frig on and loaded ready to go.
Thanks. I have covered all you have mentioned.
zackyboy3rs
Damage to my TV? Difficulty when trying to unhitched? Those are my concerns. Are those not normal thoughts?
WE-C-USA
Frank & PJ
2022 2500HD GMC Duramax 4X4
2018 Grand Design-Refection 303RLS
KD4UPL
rhagfo
Only question would be 12 volt draw from the trucks battery. I know many Ford and GM disconnect the 12 volt to the trailer when the ignition is off. My Ram still has 12 volt with the ignition off. Other than that not an issue.
