How tall is my rig
bbaker2001
Have 2001 cardinal
No paperwork on specs.
Would like to know how you get an accurate hight of trailer
Is using just a tape measure accurate enough, or do some truck stops have something
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
26 REPLIES 26
allen8106
I set a 10 foot 2x4 on top of my tallest point (AC Unit) with a level on it to ensure it was level. I had my son-in-law measure from the bottom of the 2x4 to the ground, 12' 6".
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
Johno02
Don't know.. When we bought ours, it had to go into dealers shop for a few minor things. I asked them to measure it and give me a good number. When we went to get it, there was a new sticker with permanent black numbers , and the word Height stuck on the speedometer where it couldn't be missed. Using that, we haven't had any problems.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
bama2
dapperdan has the best response to the question with a perfect picture.
never rely on specs that come with 5er. too many variables with tow vehicle etc.
imho.
Wild_Card
How tall is my rig? = the height from the ground to the tallest point measured in inches.
2015 Ram 3500 Dually
Sundowner 2286GM Pro-Grade Toyhauler
Durb
A have a tool called a Compulevel that will give me a digital readout to within 1/8". Even though it would be easy to do I have never measured the height of my trailer. I just assume it is 13'-6" and react accordingly.
enblethen
I screwed a phenolic label with US and metric to the dash below speedomter
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Allworth
And just in case you should ever go to Canada; convert it to Meters and write that down too.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
J_R2
cbshoestring wrote:
J&R wrote:
13'-6" is maximum allowed build height per federal law. Both commercial and non commercial vehicles in U.S. As others have said you must measure your own for individual height.
It is NOT a question of know the maximum allowed by law...it is a question of knowing YOUR maximum...
Point being it will not be higher than 13'-6". As the sign in your picture indicates 8' why would anyone take a possible up to 13'-6" and even try. Highways with clearances less than 15' are supposed to be posted as to height.
Ron & Joanne 06 Revolution LE 40E
mileshuff
dedmiston wrote:
Couldn't you find an example without the plumbers crack?
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
mileshuff
The brochure lists the height at 12'8" with A/C.
https://library.rvusa.com/brochure/2007_Cardinal_FWTT.pdf
Edit: Nevermind, misread OP's year!
dapperdan
What the "experts do is to get up on the roof and from the top of the highest point, usually the AC unit is take a 4' or better yet a 6' level and set it on the AC unit hold it at "level". Have somebody on the ground take the tape measure and measure from that level to the ground and now you have a very accurate measurement. That's what was done with my unit last summer while at MOR Ryde having my suspension raised.
Dan
SanMarMor
I'm lucky enough to have a barn I can park in. I stop with the front AC under the door frame, and measure from the door frame to the AC, then from the frame to the ground and subtract. If you can find something you can stop under and do the measurements, that's the most accurate way to measure. Mine is 12' 10-1/4".
Mark
2007.5 Chevy 3500HD Crew DMax Dually 4x4 w/ Curt Q5 20K Hitch
2011 Sabre 31RETS-6 w/ TrailAir Pin
44 nights in 2013, 37 nights in 2014, 27 nights in 2015, 29 nights in 2016
34 nights in 2017, 27 in 2018
http://camping.morrises.com/
cbshoestring
J_R2
