โJun-29-2020 05:32 AM
โJul-07-2020 04:47 AM
โJul-06-2020 08:58 PM
JIMNLIN wrote:Highest 15" I know is Tow-Master SS TD15225F 95 psi and 3150 load rating.
The big problem is finding a 15" trailer wheel that up to 110 psi and carry 3500 lbs.
โJul-06-2020 08:57 PM
JIMNLIN wrote:cwstanley wrote:
looking too, for 2019 373rbs just cause I don't want to tempt Westlakes, just did 3000 miles with them but ๐ No one here mentioned Sailun's I'm real tempted to go with Sailun G rated.... thoughts??
You may have a Open Range 373RBS with a 15500 gvwr. Most likely has 7k axles and hopefully 110 psi rated wheels..... so the Sailun S637 ST235/80-16" G at 4008 lbs is a excellent choice. Your getting a top of the heap commercial grade all steel ply carcass tire.
โJul-06-2020 08:45 PM
โJul-06-2020 08:05 PM
midnightsadie wrote:
good year endurance have worked good for me.
โJul-06-2020 04:11 PM
โJul-06-2020 02:28 PM
2013 F350 Dually,4X4, CC
2017 Laredo 340FL
Wife, son & 3 Brittany Spaniels
โJul-06-2020 12:02 PM
StirCrazy wrote:I check, and air up my tires before every trip, EVERY TRIP. To date I have had 3 catastrophic tire failures. Each and every one was on a tire in the beginning of it 4th year of service. they were not over loaded, and the PSI was exactly where is was supposed to be. Age killed them.
I am of the opinion that to many people change out perfectly good tires because of a name. I am not sure if we are just getting lazy and dont want to include tires as part of out trailer pretrip or what. ST stires or maybe any tire, but the show I was listining to said even the chinese tires have a life expextency of 6 to 9 years. I was looking at the tires on my 5th two weeks ago gtting ready for a trip and I noticed some weird wear on that one and then I noticed the teltale sidewall dimples of a tire starting to seperate. so I checked all the rest, no cracks in between the tread or anywhere else so I just changed the one. now this tire was on the trailer when I bought it new in 2016 so probably 5 years old and just one of the defects. my last trailer I went 10 years on the tires before I changed them out with no issues. the trailer before I went 8 years then traded it in. they were all "china bombs"
so even with the "off shore tires" if you include the tires in your daily checks, looking for cracks on the sidewall , inbetween the treads and keep the cold psi proper, you can probably get the max life out of them with out any other dammage.
would I like to buy sailun tires you bed, but they are pricy up here but not crazy. but I think the reason I would be buying them is for reduced rolling resistance and better tread life.
Steve
โJul-06-2020 07:59 AM
C Schomer wrote:
I've gotten anywhere from two years to four years and two months out of ST tires before they exploded. Now I only use 16 inch commercial LT's and the weight rating has been high enough for my trailers but sometimes just barely? I like the speed rating and LT tires are built to passenger carrying safety specs. Craig
โJul-05-2020 07:41 PM
โJul-05-2020 07:38 AM
โJul-05-2020 04:57 AM
Huntindog wrote:DogTrainer wrote:When I made the jump to LTs in 2006, I put my old tires/rims on craigs list. Got 150.00 within a couple of hours. Lots of landscapers always looking for trailer tires with rims.
Thank you so much for the information and I look forward to some new safer tires on the trailer.
I don't want to change the size of the rims...but let me look at what you all recommended and the cost if I did move to 16's.
That can help defray the cost of making the jump.
I have never looked back.
One thing to be aware of though, 16s usually require 6 lug drums. You likely have those anyway on a 5ver though. It is the TTs that can go either way.
One thing is for sure though... Going to 16s opens up a huge array of tires to choose from.
โJul-04-2020 09:06 AM
โJul-03-2020 10:50 PM
โJul-03-2020 08:22 PM
JIMNLIN wrote:Terryallan wrote:JIMNLIN wrote:
Maxxis has been left behind still rated at 65 mph. With over 30 member reporting issues with them I would stick with a more modern brand ST class tire.
Actually not so. My new Maxxis Ds have a 87 MPH speed rating at 65psi.
Maxxis 2020 website still say 65 mph max speed.
Maxxis ST8008 2020 website warranty says warranty is no good if that speed has been exceeded.
If the tire has 87 mph on the sidewall then I would say Maxxis hasn't upgraded their website. It would be to their benefit to advertise that upgrade.
