Issues with project waterpump
jayhardy
I have a 2014 Montana that came with a project Waterpump. I can't get it to work. I filled the water tank, turned on all the faucets, and then turned on the pump. I can hear it but no water flowing after 5~7 minutes. Any thoughts and where I'm doing wrong.
16 REPLIES 16
C-Bears
I have an appointment for my 2014 Montana next month at our dealer for same water pump problem.
If mine is disconnected from the fresh water tank line and instead pumped out of a 5 gallon bucket of water it works great. Therefore, the water line that goes from my fresh water tank into the fresh water pump is either not connected right at the tank or could have a split/hole in it along the way.
Anyhow, that line is inside the underbelly and travels back to the rear of the unit where the fresh water tank is located. I am still under warranty so I am going to let them drop the underbelly and fix this issue.
2014 Montana 3725RL (Goodyear G614 Tires, Flow Thru TPMS)
SPENDING THE WINTERS AT OUR HOME IN SW FLORIDA. THE REST OF THE YEAR SEEING THE U.S. FROM OUR LIVING ROOM WINDOW!
wvcampers
Had to pour water in the winterizing line with the pump running to prime the pump one time. Then switched it to the water tank and it started pumping. That was 2 years ago and have not had to do it again. Pump works every time now.
2017 F350 6.7 CC Lariat DRW
2018 Cardinal Luxury Edition 3250 RLX
Old-Biscuit
jayhardy wrote:
That might be something. When the dealership checked Mr out last year they said if we leave the switch one way or another I'll never have to worry about having hot water. It will always be on. maybe that's something I'll try it tomorrow in daylight
From this and other comments you have made I'm thinking you have a 'wet bay' (compartment where water connects) and a 'water panel' where you open/close various valves/switches that allow for city water use, filling of fresh water tank, pump use etc.
IF that is the case.......you must be sure that the valves/switches are properly set are you will never get the pump to move water thru plumbing system.
If you have a fill valve/switch and it is not in correct position for pump use the pump will suck water out of fresh water tank ad then flow back to fresh water tank via that fill valve just going 'round robin' and will not build up any pressure in plumbing system
Something like this (water panel on rightside)?????
2324delk
I had a similar problem once.
The pickup line connected at the pump was tight but a little on the cross threaded side, allowing air to be sucked into line.
I could hear it trying but no water until I took line off and restarted it.
Look for loose fitting in front of the pump.
filthy_beast
I open the low point drain for the cold water side.
Goody Two Shoes and the Filthy Beast
2008 Silverado 2500HD
2012 Wildcat 282RKX
You cannot make things idiot proof, you can only make them idiot resistant.
jayhardy
jayhardy
You would think by now I would have success. Luckily I have land water. My wife said it worked last summer but I'm not so sure. Hate to visit RV shop for something so simple. I'll keep trying
tn_terry_t
are you filling up the water heater ? I don't get any water until the heater is full or bypassed
SailingOn
I left the water pump on for a week once with no water in the tank.
No apparent damage.
Drained the battery, though.
Buck: 2004 Wilderness Yukon 8275S, now memories.
Star: Open range LF297RLS. 2 air conditioners!
Togo: 2014 Winnebago View Profile, 2013 Sprinter chassis; 16 mpg
Snow: 2020 F250 diesel
AD5GR
jayhardy
Wow. I can be quite silly at times. But all laughing aside I gave this a shot with no water. Should I leave it on for 10 minutes or can I burn out pump
SailingOn
He means the closest faucet, the faucet nearest the water heater.
AD5GR
spud1957
jayhardy wrote:
or is it the location outside with all the water hookups referred to as the closet
He said "closest" no closet.:)
2018 F350 6.7 4x4 CCSB
2022 GD Reflection 337 RLS
jayhardy
jayhardy
When u say closet faucet are you implying the lines installed for possible washer and dryer
