keeping plugged in
lee_worsdell
Should I keep my trailer plugged in all winter. Or should I unplug it for awhile and shut off the battery disconnect. Don't want to have to take out the batteries to hard to get at the trailer with the snow piled up against the front compartment. Its a 2014 Lincoln rushmore
29 REPLIES 29
centerline
yes, it all depends on the converter/charger..... a multiple stage high amp charger (something similar to the progressive dynamic charger/converters) can be plugged in full time when connected to a battery... and this will also allow for a a couple of small heaters with a "freeze-proof" setting to be kept plugged in all the time, to keep at least a minimum of heat around the plumbing areas when the temps drop down to freezing.
a quality multiple stage charger can significantly increase the life of the battery over what you will get when using a single stage unit...
2007 M-3705 SLC weekend warrior, 5th wheel
2014 Ram 3500 CC/LB, 6.7 Cummins
2004 Polaris Sportsman 700
2005 Polaris Sportsman 500 HO
1979 Bayliner 2556 FB Convertible Cruiser
Heavy Equipment Repair & Specialty Welding...
mick2268
So do you all have some sort of surge protectors you use? I burned up AC brain and a couple other switches two years ago leaving her plugged in all the time, when a storm blew through. Just turn on for an hour or so a couple times each month now.
Goostoff
I leave our Cedar Creek plugged in year round. Come spring the battery will start its 6th year of service. I told the wife last year that we should probably replace it but it lasted all year with no issues. I am still up in the air as top weather or not I should risk another year.
1993 Chevy C3500
2005 Cedar Creek 34RLTS
snipe
When the camper is home I connect to 110 to keep battery charged, at the end of the season I remove the battery from the trailer and put it in the garage, check water levels then attach a Battery Tender until spring arrives, then reinstall. Never have had to replace a battery yet.
2012 Sabre 31RETS
2017 FORD F250 Lariat Diesel
john_bet
We are on our second 5th wheel since '05. Both have been plugged in 24/7 since new. The first ones battery lasted over 9 years. The second one is plugged in now in the midwest deep freeze. Both units had and have a stock converter. I can't argue with success.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
sgfrye
thomas201 wrote:
Another plugged in all the time person, but as another said check the battery water level from time to time.
X2 im always plugged in at home , check my water levels often
Arcamper
Michelle.S wrote:
The only time our unit isn't plugged in, is when it's going down the Highway.
X2 for us.
2016 Montana 3100RL Legacy(LT's,Joy Rider 2's,disc brakes)
2014 Ram 3500 DRW Laramie Cummins/Aisin 14,000 GVWR
2014 Ford Expedition Limited, HD tow pkg
2016 Honda Civic EX-T
1999 Stingray 240LS
1994 Chevy 1500 5.7 PU
2018 John Deere 1025R
B&W RVK3600 Hitch
Lantley
x2
thomas201
AZ_T_T
I use a Battery Tender when not running the fridge.
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
Michelle_S
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
FLY_4_FUN
Just because of possible theft I prefer to pull my 2 x 6v batts in the fall. Put them on a Deltran battery tender a few times over the winter and then check fluids/reinstall in the spring. I don't use it during the winter so powering the system is a waste of $ during that time.
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
2015 Brookstone 315RL
2009 Colorado 29BHS (sold 2015)
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
alexleblanc
I just keep mind plugged in all winter, never had a problem to date with 3 difference RV's.
TV - 2017 F350 CCSB SRW Platinum 6.7 + 5er - 2021 Grand Design Reflection 311 BHS + B&W Companion
On Order - 2022 F350 CCSB SRW Platinum 6.7
memtb
We have the multi-stage chargers as well, but....we put it on a timer to charge for an hour daily. I donโ€™t fully trust the charger, to โ€œnotโ€ overcharge the batteries....so I use the timer. If you donโ€™t have the multi-stage charger, I would certainly recommend the timer, โ€œit doesnโ€™t forget.....you mightโ€!
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
