Leveling A Fifth Wheel
Calicajun
Hi,
At the moment I have a pull behind TT but looking into getting a 5th wheel trailer.
The one question that came to mind is how do you level a 5th wheel. The my pull behind TT I use with a WDH to even out the load through out the truck. I haven't seen anything like that for a 5th wheel trailer. I know the hitch sits over the rear axle but that still puts more weight on the back of the truck than the front. Also the tongue weight of a 5th wheel is much heavier than a TT tongue. :?
2014 Heartland Wildness 2775RB, 2015 Ram 2500 4x4 Mega Cab
14 REPLIES 14
Goostoff
Cummins12V98 wrote:
vinr wrote:
I have a 2013 Ram 2500 Cummings. My 5er is a 37ft Columbus at about 11k empty. My TV doesn't even break a sweat! Good luck finding the right unit.
CUMMINS
High Five!!!!!
I have 3500 dually with a Rat under the hood and a 35 foot Cedar Creek , and I am sweating bullets every time I come to a hill. The rest of the time I am calm cool and collected because I dont think a hurricane could make my trailer sway.
The 5th wheel hitches have a series of holes so you can adjust the height and level it out
1993 Chevy C3500
2005 Cedar Creek 34RLTS
Cummins12V98
CUMMINS
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
laknox
Calicajun wrote:
Hi,
To level a FW, you need to adjust 3 things; hitch, pin box and FW suspension. Most FW suspensions will have multiple holes in the spring hangars that you use for this. Also, the springs may be below the axle tube (mine is) and you can buy a kit to have the springs put on top of the axle to gain about 3-4" height. Biggest issues are making sure your FW is near-level (2-3" isn't ideal, but isn't usually an issue) =and= your truck is level. You also have to have enough clearance between the FW and the truck bed, usually no less than 6". Once you have your set up the way you want it, you just hook up and go; no further adjustments are necessary when hitching or unhitching.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
vinr
Cummins12V98
Calicajun wrote:
Thanks all,
I was wondering how the leveling working with 5th wheels.
I just bought a 2015 Ram 2500 Mega cab 4x4 with the 6'4" bed. The 5th wheels we are looking at are all between 9,000 to 11,000 pound max weight. Maybe I should say I am looking at the 9,000 pound units the wife is looking at the 11,000 pound units.
I would say those are good numbers to be looking "within" for your truck.
Cummins12V98
stickdog wrote:
A properly installed fifthwheel hitch should be 2" in front of the axle. Yes the weight is on the rear axle and should not unload the front axle at all.
BINGO!!! We have a winner.
With about 5K pin I have just under 200# of that transferring to the front axle.
noteven
We leveled our 5th wheel trailer by adjusting the height of the 5th wheel (aka "the hitch") in our truck, and the trailer's pin height using the adjustment holes provided.
Calicajun
Thanks all,
stickdog
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Allworth
My weights (with a 13,480# fiver) are very much like Garysol's.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
brirene
That's why payload of your tv is the most important consideration when considering a fiver. Hence the adage "you can never have too much truck".
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
garysol
My 14,000 pound 5th wheel puts 2,840 pounds on the rear axle but no extra weight onto the front at all.
2020 GMC Canyon
2022 NoBo 19.2
is_it_friday_ye
Most have at least a 3/4 ton or 1 ton (SRW or DRW). I added air bags to my SRW 1 ton to help a bit. Mine didn't sag very much without the air bags though.
2007 Dodge Ram 3500 Cummins SRW, Airlift airbags, Bilstein shocks, Smarty Jr., stainless turbo back exhaust, B&W Patriot 18K
2015 Grand Design Momentum 328M, disc brakes, Progressive Industries 50 amp EMS
Water-Bug
A TT loads the TV behind the rear axel, this unloads weight from the TV front axel. A 5er loads the TV rear axel, without unloading the TV front axel. TV are by design front axel heavy. The engine and transmission typically load the front axel of the TV. Excess pin weight does unbalance the TV, but as long as you don't exceed the load capacity of the TV, 5er handle better than TTs.
