โApr-20-2023 08:17 AM
โApr-28-2023 07:24 AM
C Schomer wrote:
My last several trailers have had 6K axles, and I will only use 16 inch LT tires. One manufacturer told me that ST tires are not built to the safety standards that any tire for carrying passengers are. Craig
โApr-28-2023 06:12 AM
โApr-28-2023 06:02 AM
โApr-24-2023 01:42 PM
โApr-24-2023 06:25 AM
โApr-24-2023 06:22 AM
โApr-23-2023 08:01 PM
โApr-23-2023 09:48 AM
โApr-23-2023 09:22 AM
StirCrazy wrote:So the thinner more flexible sidewall makes them more resistant to twisting and scrubbing? Nope, not buyin' it. ๐fj12ryder wrote:MNRon wrote:I've heard that tons of times that ST tires have stiffer sidewalls, none of which I've ever seen in the real world. ST tires have wimpy sidewalls compared to good LT tires. The old ST dealer's story keeps coming up and refuses to go away, even though it's wrong. Repeating wrong data doesn't make it right.
StirCrazy - good comments here about LT vs ST specs and testing. What hasnโt been mentioned yet is that ST have stiffer sidewalls for the tire scrubbing that will happen on tandem and triple axle trailers. LT are designed with more margin and to higher standards, but they are designed for a different application than ST. I would recommend sticking to ST, and specifically recommend looking at Sailuns (that I have good experiences with - besides, much cheaper than a good LT tire).
they don't have thicker or stiffer sidewalls they have sidewalls made to take the twisting and such from sharp scrubbing turns better. people tend to explain/interpret that wrong
โApr-23-2023 09:20 AM
StirCrazy wrote:That sounds like typical CYA. If they say you can run the pressure you feel is suitable for your trailer, then when someone ruins a tire due to excessively low pressure, they blame the company because they said it was okay to run lower pressure.fj12ryder wrote:StirCrazy wrote:I've run Sailun's at less than 110 psi, but not as low as 80 psi. I ran mine down at 90-95 psi, with no issues and they lasted 6+ years and still looked good. I had a triple axle at the time and my load was about 5,000 lbs. per axle, so they were way over tired.MNRon wrote:
yup and that's what I have always said myself, but I was looking into it as a few new rv's are coming out with LT tires, so it muddies up the water. I was going to go with sailun but after talking with them, they should be run at 110psi not at 80, so that would mean I would need new rims also. more to think about.
ya I was just going by what sailun told me. They said they should be run at full pressure for best tread wear, fuel economy and tire life.
โApr-23-2023 07:01 AM
โApr-23-2023 07:00 AM
โApr-22-2023 06:53 PM
so when looking to switch if my tires I have now are 235/80R16.. what size of LT tire should I be looking for since that size is exclusive to st tires.
โApr-22-2023 12:11 PM
