โMar-14-2017 03:00 AM
โMar-20-2017 07:25 PM
sc1camping wrote:
I have a GD Momentum and run all 3 ACs at the same time. If all 3 were running and you added additional load by turning on the microwave or something automatic such as hot water heater, fridge, battery charger it is possible the load management system could shut off one or more ACs.
Most of these issue can be avoided by running fridge and water heater on gas only in very hot weather.
You will need all 3 ACs running hard in the South when temps go 90 plus with high humidity. This is only in late afternoon with direct sunlight.
โMar-18-2017 04:20 PM
โMar-15-2017 09:10 PM
โMar-15-2017 10:32 AM
โMar-15-2017 09:21 AM
ramgunner wrote:
I'm a little confused. Who at Grand Design told you you can't run a three AC units at the same time on the 395M?
Scott Broussard Regional sales
Are you sure they were talking about being hooked up to 50A service?
Nope not sure but have been told the same for the 399 also by dealers
If you are running on the generator, then yes you can only run two at a time. But on 50A power there should be no issues with running all 3.
โMar-15-2017 03:01 AM
โMar-14-2017 02:50 PM
arhayes wrote:
We have a GD 380TH which is the same size as the 385. I also can run all 3 AC's on 50 amps. The insulation is adequate in the living area and bedroom, but because of the large windows in the garage and the back ramp, it tends to stay a little warmer. If I was going to spend time in hot climates and use the garage area for living space, I'd probably put the reflective insulation on the windows to reduce some of the heat. With that said, we are in 90 degree days right now in AZ and we are comfortable.
โMar-14-2017 09:39 AM
โMar-14-2017 09:06 AM
โMar-14-2017 07:48 AM
ramgunner wrote:
Keep in mind that on 50A service you can run all 3 AC units (if it has three) at the same time.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โข <\br >Toys:
โMar-14-2017 07:00 AM
โMar-14-2017 06:53 AM
