โApr-01-2014 07:33 AM
โApr-02-2014 01:20 PM
โApr-02-2014 12:31 PM
โApr-02-2014 11:59 AM
I'm Rick James wrote:broccoli2 wrote:I'm Rick James wrote:
+1000 It appears the first response could have ended the thread.
Thank god your here with insightful coment
Thank God you're here to make me thankful that I learned proper grammar.
โApr-02-2014 11:54 AM
โApr-02-2014 10:00 AM
Ric Flair wrote:
But what fun would that have been?
โApr-02-2014 09:59 AM
โApr-02-2014 07:17 AM
โApr-02-2014 07:06 AM
I'm Rick James wrote:sptrucksbyed wrote:
Here we go again !! You have allready been told by MANY that with that trailer you need a dually but you got mad at everyone because you knew what you were doing !! Now why ask people what you have allready been told the answer and now know ???
โApr-02-2014 06:19 AM
โApr-02-2014 05:52 AM
Lyrikz wrote:I've found that my off-pavement traction is lousy when I'm unloaded, and just fine when I have a ton of pin weight pressing down on the rear axle. I have 2-wheel drive, so I'm not the right person to give you an opinion on how a 4x4 dually will handle in sand. I'm sure others here can chime in.Stefonius wrote:Lyrikz wrote:Duals will definitely cost you some off-roading capability. They ride up on top of marginal surfaces (water, mud, snow, sand) as though you were wearing snowshoes.NRALIFR wrote:Unfortunately i need SOME ride and some off roading capability.. I had a hard time in some sand. ONe of my friends is a rep for ATD tires. He was the one who recommended the 622s. Dang. I cant win. lol
From the tow vehicle pic's topic, you say you have "Goodyear 622's and 19.5 visions" on your truck.
While there are certainly other factors contributing, I don't think the G622's are the right tire for your rig. While they may have the weight rating needed, the "Unisteel" construction has the steel belts only in the tread area. I would look for some tires that have steel in the sidewalls as well, which will stiffen them up a lot.
You will probably lose some off-roading capability, and you may not like the ride, but they won't flex like the tires you have.
That seems like a positive for sand right?
I dont do a lot of 4x4. I just dont want to negate that totally.
โApr-01-2014 03:44 PM
mrxlh wrote:
HDT Volvo or Freight Shaker with under 800k on it can be had for 20K or under with new rubber. Pull an axle, super single the remaining move the 5th wheel behind the rear axle viola problem solved for half or a new truck, plus you can keep the one you have. My F350 dually tows my 4014LEV Raptor just fine, I have the 4.10 gears and am on the fence if 3.73 would be an improvement. It still knows its back there however. If you get a Schenider truck with the 2.32 gears in it with super singles , you should easily achieve double digits towing you camper fully loaded. This is going to be my next move.
โApr-01-2014 03:38 PM
fly-boy wrote:
If that was without water than I think a dually would be the right choice.
Something is not right with those weights-
โApr-01-2014 03:29 PM
โApr-01-2014 03:21 PM
