Opinions Dometic or Norcold refrigerator
slotsavegas
My current Dometic RM2862 is a 2005 model and the cooling unit is failing. I can purchase a Norcold at a heavy discount, but do not know if the Norcold model is as reliable as the Dometic which I cannot get at a discount. I can purchase a Norcold for about the same price as a new cooling unit for my current Dometic.
Looking for opinions from others.
PLEASE... No comments about home style or compressor models as they are NOT and option.
21 REPLIES 21
Old-Biscuit
old guy wrote:
I've had both and the one thing I think Norcold has over the Domectic is you can adjust the frig temp in the front of the fig with out moving a thing up and down inside the domectic. other than that I don't think there is much difference in functionality.
Not all Dometics....just ones with pre-set thermostat.
OP's Dometic has adjustable thermostat settings (1-5) on upper panel
Norcolds also have thermistors on fins in food section.
Old-Biscuit
Which Norcold are you considering?
Dometic/Norcold are basically same.
Both have basic models and both have ones with bells and whistles.
They are absorption fridges....operate on same principle.
Side by side they do the same thing--equally well.
Biggest issue is not with fridge BUT RV mfg. installations.
Mess that up and neither preform very well.
Which Norcold is it that you can get at a great price?
NEW or Used?
Big_Katuna
They are both cheaply made. My Norcold 1200 recently failed.
I replaced the cooling unit with an Amish made. It is much better made than the factory unit.
In my case I would have replaced it with a res unit but that would mean taking out a window. Same for a new unit.
A new replacement CU is a third the price of a new fridge.
My Kharma ran over my Dogma.
phillyg
I don't think it matters, expect to your pocketbook.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
TucsonJim
You might also take a look at the new Atwood helium refrigerators. They aren't as sensitive to being out of level. They did have some problems with defective electrical heating elements caused by a supplier, but they've worked through those now.
Atwood Helium Reefers
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
enblethen
I have had both.
Quality is about the same.
Each have had their problems.
It would be a coin toss in favor of the less expensive one
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
old_guy
